Flat Tow Equipment Availability?
PhillyGuy
Tony
Chester County, PA
2014 F150 SuperCrew Platinum, 2018 BMW X3 M40i
Does anyone have information on when manufacturers such as Curt Manufacturing, BlueOx or others will have flat tow equipment package ready for the 2021/2022 Broncos? I intend on having the dealer install for me upon delivery.
grtharris
Grant
Skiatook, OK
Outer Banks 4dr, 2008 Mustang GT CS (Wife's), MH
Blue Ox said they are waiting on New Bronco to build a base plate.
My plan, until Ford saids no, is to use the D-ring shackles on the modular bumper.
The Bronco shackles are wider than normal, looks like 1 1/8" the best I could measure wiithout
touching. So again my plan in to open up the Blue Ox adapters which have a 1" opening to fit the Bronco.
I'm using a Brake Buddy Stealth braking system on my Jeep now. Which I really like.
Still studying the rear lights as the OBX has led tail lights.
PhillyGuy
PhillyGuy
Tony
Chester County, PA
Thanks much! I've ordered my bronco with the modular bumper and was wondering if I can do the same and not install a base plate. I've seen Blue Ox parts for LED tail lights on the F150 so my hope is it's the same for the Bronco.
JesseS
Jesse
Northern California
Jayco AY26, Honda F6B, CR-V
I am sure BlueOx will have a tow bar end adapter to fit before we get them, they already have a 1.1" one for the standard 1" shackle (why Ford couldn't stick with the 1" standard I don't know). As for the lights I will wait to find out if diodes will work, if not I will just add a LED surface mount RTB light to the back, or if there is room in the OEM assembly add a plug in LED light & socket, several options.
Ford Bronco Flat Tow Equipment Availability? 81wQpNstruL._AC_SL1500_
grtharris
Grant
Skiatook, OK
Blue Ox has a new 7/8" pin adapter the part number is BX88357 it has a deeper throat.
Ford Bronco Flat Tow Equipment Availability? BX88357
JesseS
Jesse
Northern California
Blue Ox has a new 7/8" pin adapter the part number is BX88357 it has a throat.
But what is the clevis opening dimensions? I am not milling out and weakening the arms, just my luck they would let go and coverage denied due to unauthorized modification of safety equipment. :) I will wait for a Bronco specific adapter, it will be along soon.
