First Edition Bronco Thread
What interior color do you want for the FE
  • Total voters
    580
BroncoHooves
Austin, TX
One of my two favorite grilles. I think it's on the Black Diamond, but of course I would want it with the signature LED headlights. Not even sure if this grille would be compatible with the signature headlights.
Ford Bronco First Edition Bronco Thread jABU33C
jmalinov
Clay
Bossier City, LA
2019 Ford Explorer, 2018 Ford Fusion
You’ll probably be able to swap grilles after anyway. I swapped the grill on my F-150 to the honeycomb grille after I bought it.
Did u really? How hard was it? I have zero manly skills, but my father in law is great ?
rmc523
South Florida
2022 Bronco Wildtrak
Does anyone even know the difference between Sport Mode and Baja Mode? Like, for certain?
So, I found a press release from 2017 for the Raptor describing the different modes, and below is what it says for Sport and Baja modes. Obviously it won't be direct carryover, but it's likely similar.
Sport
Mountain passes are no longer just for Mustang, thanks to Raptor sport mode. For spirited on-road driving, sport mode increases throttle response and provides a sportier steering feel – along with quicker shifting. The transmission holds gears longer to keep you in the power band.
Baja
Baja mode is where Raptor eclipses the competition. Designed for high-speed desert running, Baja mode places the vehicle in 4 High, AdvanceTrac is programmed to the least intrusive settings, and the throttle map is adjusted for more linear power and improved engine response to give the hardcore off-road driver greater control. The transmission has quicker shifts and holds gears longer – keeping the vehicle in its power band.
https://media.ford.com/content/ford...es-where-we-re-going-we-don-t-need-roads.html
Raptor's other modes (Normal, Weather, Mud/Sand, and Rock Crawl) are also on there.
Haulin455
Ford F-150
It took me a couple hours but that’s because I also swapped out the headlights which are more difficult to do. If you are comfortable popping some tabs and removing some bolts it’s really straight forward. There will likely be YouTube videos posted that show you how to do it if you decide to go that route.
GordoJones
TN
Explorer
The Big Bend with standard headlights has the same grill as the Outer Banks, Wildtrak, and First Edition with signature headlights. Hence standard and signature headlights are the same shape, so grills should be interchangeable.
vintage
Summerfield, N.C.
Wrangler JLU Rubicon, 4Runner Trd Pro, Indian Chieftain, Indian Springfield
Painted black grille on the FE is my favorite. Dang there another reason I need to stick with FE. ?
Ford Bronco First Edition Bronco Thread images (36)
Bronco4
Frank
Medford Oregon
2017 F350 CCLB
snooping around the Ford Bronco web site looking at First Edition Interior Features it lists Rubberized Flooring. I hope this is true. But the General description of the FE states that it has the interior of the Outer Banks, which has carpet flooring.
Any thoughts or information would be appreciated.
Boston182
Matt
San Francisco, California
Harley Davidson Sportster
Rubberized floors with removable carpet mats, as I understood it.
Boston182
Matt
Can you think of any reason why you couldn't use Baja as a sport mode / on the road if you've got First Edition/Badlands that doesn't have the proper sport mode?
vintage
Summerfield, N.C.
Seems to be conflicting info on FE. Somewhere else shows the 'honeycomb' grille on the FE.
Interesting this article said FE gets same grille as Big Ben, Outerbanks and Wildtrak. Where are you referencing it gets Honeycomb Grille.
Ford Bronco First Edition Bronco Thread Screenshot_20200801-175329_Chrom
Indominus49er
Las Vegas
Alfa Romeo, Honda
No, just shift it out of 4wd like raptor guys do=better than sport mode. Just did this last week in my buddy's Raptor.
Boston182
Matt
Never had or driven a car with modes, so pardon my ignorance.
Sport Mode = Baja mode, but 2WD
Baja Mode = Sport mode, but 4WD (and you can manually turn off 4WD and into 2WD for roads, so essentially Sport Mode)
Makes you wonder why WildTrak has both Baja and Sport Modes when/if you can manually toggle 4WD/2WD in either.
BroncoHooves
Austin, TX
It came from the configurator images I grabbed before they pulled it. It was on another Ford page as well; trying to find where it is/if they removed it. They've been back peddling like crazy.
