Fire extinguisher recommendations? Rear mounted options?
Area51BS
Ron
Badlands non SAS 4dr 2.3
Might be wrong section. Looking for rear mounted mounted extinguisher recommendations that require no mods. It could be life saving.
Deleted User 5719102
Who's
On a Lake
22 2dr
Ohnoohnoooo
St. Paul, Minnesota
BMW z3, Nisan rogue, joint-custody of Jeep YJ
I have this:
Adjustable Strap Bracket Mount https://a.co/d/asrhdOk
I strap a 2.5 lb extinguisher to it. I also keep a small one under the front seat.
Who iz
Otis
End of the Oregon trail
F250, 4Runner, Jimmy
rainman23
Ray
Salem, OR
F-150
Who iz
Otis
Do the holes actually line up with the pre drilled holes in the roll bar?
Short answer no....But very easy to mount on any number of panels. Will post an image when I have light for the image and have the time. Takes no skill just time to secure it well, so no rattling on the trails.
Sorry OP...But perhaps small modifications are ok? :cautious:
as promised> cargo area dual mounted extinguisher images:
Ford Bronco Fire extinguisher recommendations? Rear mounted options? fire ext.dos.c.2
Ford Bronco Fire extinguisher recommendations? Rear mounted options? fire ext.dos.b.2
Ford Bronco Fire extinguisher recommendations? Rear mounted options? fire ext driver.side.2
Ford Bronco Fire extinguisher recommendations? Rear mounted options? fire ext passenger.side.2
BCKMRKR
James
NorCal
'22 Wildtrak 2-Door, '19 Miata, '15 M235i
Not sure what you mean by no mods. No drilling, just replace tailgate panel with Molle panel. Added benefit is that it is out of sight. Not cheap though.
https://coursemotorsports.com/collections/quick-release-fire-extinguisher-mount
Black/black quick release, black Halotron, and Molle panel for my tailgate. Easy install, almost completely vibration free (the top pins/zip ties of the extinguisher need to be kept from slightly moving with a rubber band or hair scrunchy).
Wildfire1
Paul
Nfld, Canada
1993 GMC 4X4 / 2012 Mustang convert
I mounted a fire extinguisher on each side of the rear bar. I cut a couple of brackets on the CNC that fit the existing threaded holes in the bars and simply bolted them on.
Ford Bronco Fire extinguisher recommendations? Rear mounted options? IMG_4609
Ford Bronco Fire extinguisher recommendations? Rear mounted options? IMG_4614
Ford Bronco Fire extinguisher recommendations? Rear mounted options? IMG_4613
Ford Bronco Fire extinguisher recommendations? Rear mounted options? IMG_4612
Ford Bronco Fire extinguisher recommendations? Rear mounted options? IMG_4615
THE Buckeye Bronco
Norfolk, VA
2022 Ford Bronco, 2021 BMW M4 Comp
Heare's what I did: Buckeye brand (obviously) 2.5Lb extinguisher mounted with Rough Country's fire extinguisher mount. Utilized the bolt hole on the roll bar and one of the T50 bolts from the hardtop bolts as I had installed Rock Workx thumb screw quick removal fasteners. Then a plastic plug in the other existing hole just for alignment.
Ford Bronco Fire extinguisher recommendations? Rear mounted options? 20230425_165709
Ford Bronco Fire extinguisher recommendations? Rear mounted options? 20230425_165719
Ford Bronco Fire extinguisher recommendations? Rear mounted options? 20230425_165748
Combustion_King
Derek
MA
Yes
If you guys get cheap plastic ones, be sure to check them often, they do leak, and I’m sure the conditions off-road, higher chance of damage. Safety first! Lol
mcinfantry
Lee
Louisiana
Badlands 2 door
Ford Bronco Fire extinguisher recommendations? Rear mounted options? IMG_1143
I couldn’t pass it up at 60% off
and no residue
BroncoAZ
Mitch
and no residue
Link? Looks like 4WP, but I can’t seem to find it on their site. I would like to get another at that price.
mcinfantry
Lee
Louisiana
Badlands 2 door
It was 4wp
I check about once a week and will buy another as soon as I catch that sale again
mcinfantry
Lee
Louisiana
Badlands 2 door
Ford Bronco Fire extinguisher recommendations? Rear mounted options? IMG_1142
I missed that by a day
