Finally installed soft top- weird gap in trunk?
ryanc721
Ryan
2026 Big Bend Sasquatch
Has anyone else had an issue with their being a 1/4-1/2 inch gap in the trunk area where the soft top meets the body of the car? I used the alignment brackets and everything and theres still a gap...
Tonka Bronka
Duncansville
F350, V60 Polestar, 900SS, K1300S, RnineT Racer
Can you post a photo and I'll compare it to my factory installed top.
ryanc721
Ryan
Ford Bronco Finally installed soft top- weird gap in trunk? IMG_3724
Ford Bronco Finally installed soft top- weird gap in trunk? IMG_3722
Ford Bronco Finally installed soft top- weird gap in trunk? IMG_3721
Sandbergo
Jelani & Dave
Orlando
Rogue
Can you post a picture of the mounting hardware behind the back panels, makes me wonder if it’s not sitting flush because the bottom brackets are set too high.
ryanc721
Ryan
I’ll post a pic in the morning. But I used the alignment hardware so I feel like that shouldn’t be the issue ?
Tonka Bronka
Duncansville
Yes, something is not right, shouldn't have daylight like that. Hard to tell what without being there. Maybe someone here who takes theirs completely off and on again might have some insight.
ryanc721
Ryan
As requested
Ford Bronco Finally installed soft top- weird gap in trunk? IMG_3736
Ford Bronco Finally installed soft top- weird gap in trunk? IMG_3737
Nc211
Washington DC
No, that's not right and something is off. Here is mine. Look at that front hinge how it overlaps the plastic trim piece. Yours is sitting above it for some reason, and I think it's in your mounting bracket. Mine is level. Yours appear to be lifting upwards towards the front of the vehicle, not perfectly level. I'm not sure why or how to fix that?
Is your ST the same model year as the car? Did Ford make some changes to the mounting structure along the way and maybe you got the wrong year soft top? I honestly don't know...
Or can that pin plate behind the bracket be adjusted at all? Looks like it needs to be lowered and leveled?
Ford Bronco Finally installed soft top- weird gap in trunk? IMG_8141
Ford Bronco Finally installed soft top- weird gap in trunk? IMG_8133
Ford Bronco Finally installed soft top- weird gap in trunk? IMG_8140
Ford Bronco Finally installed soft top- weird gap in trunk? IMG_8139
Ford Bronco Finally installed soft top- weird gap in trunk? IMG_8137
Ford Bronco Finally installed soft top- weird gap in trunk? IMG_8138
Ford Bronco Finally installed soft top- weird gap in trunk? IMG_8136
Ford Bronco Finally installed soft top- weird gap in trunk? IMG_8135
ryanc721
Ryan
Interesting. Do you think I can adjust this with the soft top still on? Or would I have to take the entire thing off ?
Nc211
Washington DC
I think you'll need to take it off. I think that bracket with the resting pin needs to be adjusted and leveled, if it can?
ryanc721
Ryan
Well that’s the issue. I used the ford supplied alignment tool. So now I have to align it by hand which makes me think I’d have to do it while it’s on…
Big Pony
Subaru Ascent LTD '20
Following this. I’m actually waiting on some parts to swap to the ST. Had mine still in the pallet and thought I had everything I needed to install but was missing quite a few important parts. Hopefully I ordered everything I needed and can install soon. Wondering if I’ll run into any issues. @ryanc721 , what is this leveling tool you mention? Can you share a picture or part number?
‘21OBX
90Bronco19
2022 bronco outer banks
What alignment hardware are you referring to? And no you have something too high ours seals properly. In the one photo you have a lot of adjustment in the bracket that is bolted to the body near the tailgate.
ryanc721
Ryan
When you order the bracket, it comes with an alignment tool that you mount temporarily to the body, then you take it off and mount the soft top to the bracket
‘21OBX
90Bronco19
Hmm ours ya always been a soft top so I didn’t know they sent something out. Apparently that tool is set too high. I’ve taken our complete top off make sure you sit tight to the alignment pins when re installing. I’d measure that gap and lower the brackets the required amount.
