Fender removal for Bronco Raptor - instructions / guide?
Turbo yzel
DMV
Braptor
They are “removable”, but not easily like Sasquatch flares. If you want to install ppf under them it may be worth the effort, my ppf installer has done it on two. But he didn’t like it and needed plenty of replacement clips.
even if you could take them off easily, it’s ugly as sin under there
any picks
I’m looking for some kinda support to build a custom set off of
JohnGalt
Tahoe, CA
2023 Defender 110
any picks
….of flares?
I don’t have any personal pics, but I ran across this a while back…. It should give you a good idea of what you’re dealing with before pulling a flare. It’s a whole lot of ugly under there, and why we’re not seeing Sasquatch style flares in the aftermarket.
Ford Bronco Fender removal for Bronco Raptor - instructions / guide? 1702569791902
Turbo yzel
DMV
Braptor
I guess there is not much there to build a custom fender and like a metal bar to help from bashing trail objects ☹
defector69
2023 Braptor
any picks…
I have a question, does the removal of the Braptors fenders appear in any manual or is there a guide to look at?
I have no good pics - just these - and I only have front experience.
1) remove inner liner - you will break those crappy clips - the wheels can stay on.
2) “slowly” pop or pry fender flare off from rear to front. I broke no clips and reused all OE clips. When I reinstalled the clips, I had to rotate them 90 degrees to hold the flare on.
I think if any good mechanics actually give this a shot this will be reported out as much simpler than all the unclear info here so far
Ford Bronco Fender removal for Bronco Raptor - instructions / guide? IMG_1893
Ford Bronco Fender removal for Bronco Raptor - instructions / guide? IMG_1890
Ford Bronco Fender removal for Bronco Raptor - instructions / guide? IMG_1891
Ford Bronco Fender removal for Bronco Raptor - instructions / guide? IMG_1892
22 Spyder
Fort Lauderdale
2024 Azure Bronco Raptor (DD),2022 Porsche 718 Spyder(weekend)
Ok you geniuses, I just bought an 8 piece Oracle Rock light kit RGB+W part#5895-339-8. I plan to mount 4 inside the wheel wells what leads me to the 2 ideas I’m thinking of going for this install.
1) Drop the inner fender liners and install the rock lights, but I’m worried about all those push pins breaking as mentioned many times.
2) Use a rivet nut tool and some nurserts to mount the rock light fender liner while making another hole to run the wires down. The only concern I have with that option is there enough room above the fender liners and the body/parts to fish a line down? Also enough room to carefully drill a few small holes for the nutserts?
Ideally I would like the rock lights as centered as possible in the wheel wells while still being able to easily run the wires to the frame.
I would love to see a rock light install tutorial done by some pros here.
BTW, the other 4 rock lights I’ll be using magnets to attach them front center, rear center and 2 more middle center.
Any info or tips would be great. Thx
