Fender Decal Removal Question
Junior127
Jack
Brockport NY
2022 Big Bend, 2019 F350, 1992 Mustang GT
Hello, I have seen posts were some have removed the fender decals and was wondering when you did if you could tell it used to be there based on a difference in the paint color, an outline of the decal or anything like that.
The decal just seems out of place to me and I would like to remove it but not if it would be noticeable that it was removed. That would be something I would focus on and it would bug me.
Thanks in advance for any input.
Lindy08
Cliff
Illinois
2009 F-150
Took mine off the day after I brought it home. Could not tell it was ever there.
Came off easy after a little hairdryer heat.
Hartzco
Valparaiso, IN
2021 Bronco BD Sasquatch
I removed mine within a month or so of delivery and couldn’t tell whatsoever that they had ever been there.
HotdogThud
mk6 gti, '21 MoarDoor
Yep, remove it quick and there's no paint worries. @Lindy08 is right, hit it with a hair dryer, heat gun, or park it in the sun on a hot day and it'll peel right off with a little care.
I ended up putting mine on my beer fridge in the garage, seemed a good spot
Junior127
Jack
Brockport NY
Just picked it up a week ago so sounds like I'm good to go. thank you everyone
tractorcrusher
Curtis
DFW, TX
Mine popped off no problem using a plastic spatula, just make sure you're not pressing into the paint. I immediately put it on wax paper so I can put it on something someday.
Tdub0527
Ted
Minneapolis
'21 Bronco Badlands, 2024 Rivian R1S
Came off easy with no visible evidence it was ever there. Good luck!
AZSky
Scottsdale, AZ
Heritage, Mach E, EV6
I did the same before PPF install. Now, for the horse, the sticky tape is damaged and I need to find a good brand double sided tape - 3M ? Also, cut to shape with a scalpel around the outline ?
mybikeisred
Paul
Carmel, CA
F250 Powerstroke, Grand Cherokee
Yeah, peel away, you’re good. I didn’t even have to use heat or anything, just dug my thumbnail under a corner.
BOLD Renegade93
Bossier City, LA
2021 Ford Bronco Black Diamond
I’ve had mine since November and just took them off last week. One of them came off perfectly with no residue, the other came off but left a good bit of residue. Goo Gone took care of the rest!
I didn’t use a heat gun or anything, but the car had been sitting outside in 100 degree temps all day so it was a warm surface for sure.
