Fake sub/amp...Now what?
dingle87
Reese
West Suburbs of Chicago
2019 Ford Explorer XLT
I think I'm going to "upgrade" my 2023 BD with these items too. I'm no audio savant, but I would appreciate a little better sound.
Is it possible to do all the replacement work physically then do the Forscan update after the fact? I don't have that capability, so I'd be looking for a roving Forscan expert to help/do that for me.
El Bronco Blanco
Matt
Scottsdale, AZ
2013 Ford Explorer XLT, 2021 Mazda CX-9
100%. I did the replacement on Thursday night.
friday my dongle was delivered and adjusted Forscan then.
dingle87
Reese
Playing catch up and saving threads, but there are so many pages. Would I need base blockers for front 4" and rear 4" speaker replacement? or just the front?
  • Like
Reactions: LCW
El Bronco Blanco
Matt
Scottsdale, AZ
I didn’t do any of that stuff. I just put the amp/sub in and it’s good enough for me. No other speaker changes.
maybe down the road… but I’m beyond satisfied for now, especially for being forced to drop LUX to get my WT.
dingle87
Reese
This sounds fantastic. I'll save money on the 4" speakers for now and just do the sub/fusion amp upgrade. Thanks!
TTUHoopsFans
Bill
Frisco, Texas
2023 Ford Bronco
If I have absolutely zero experience with this stuff, so could I easily do it? So I need to buy the amp and sub and just plug it all in? What about that sound dampening / foil stuff, do I need that? Also what is the out the door cost for this project? Lastly, I don't know much about Forscan but I'm sure I could figure it out.
Pressurized
Rod
Gilbert, AZ
Gen 6 Bronco - Jeep JKU - Wrangler LJ (sold)
Just the front if you don't do any other changes in Forscan. There is a high pass filter in the programming already for the rear.
Pressurized
Rod
Gilbert, AZ
Is that really all? No wiring/splicing/etc? Do they just plug into an existing wire harness? I have Forscan already.
Pretty much, you do have to clip the ends of the speaker leads and strip the wire back to insert in the Kicker sub terminals. Very easy.
dingle87
Reese
Awesome. Thank you for the info and reply. I'll start with adding the sub/amp, see what I think. If I'm not a fan, I'll do the fronts with base blockers. Do in steps to just see the difference.
Pressurized
Rod
Gilbert, AZ
The 4" in front make a big difference in midrange and high freq performance. Vocals are much better and it's just cleaner and clearer...
El Bronco Blanco
Matt
Scottsdale, AZ
It's VERY easy.
Rear panel removal:
using Forscan:
@RagnarKon is a wealth of info
Forscan Google Doc:
https://www.bronco6g.com/forum/thre...k-sport-mode-chimes-seatbelts-and-more.28489/
