Fake sub/amp...Now what?
TTUHoopsFans
Bill
Frisco, Texas
2023 Ford Bronco
I went on to replace the 4" dash speakers with Infinity Reference with 600Hz bass blockers and the rear pod speakers with the same without bass blockers and it made another substantial difference. I'm pretty happy with the sound now.
How difficult was this? Are there any good videos out there? Now that I’ve done the amp/sub swap, wondering if I can get even better sound but I’m the kind of person that needs crystal clear instructions lol.
Spiderwolf
Mickey
woodstock, GA
2012 Rubicon, 2016 Dodge Challenger RT Scat Pac
It's true. All 2023 Broncos were supposed to come with sub and amp. But, supply issues kept Ford from being able to keep up with production. I read (not sure if true) that since there was equipment in the test vehicles for crash test certifications, they had to have stuff there in the production Broncos. So, most of the 2023 Broncos have "sub delete" and a $250 credit on the window sticker... the fake amp has a blank system board, and the fake sub has no magnet/driver... just a cone. However, the sub housing is there, and all the wiring is there... so it makes it easy to replace with real equipment.
That’s just funny. Fake equipment. Who would have thought. Never heard of anything like that before.
Spiderwolf
Mickey
woodstock, GA
I have not heard the B&O, but I think it is still a small sub. The kicker helped the non sub system a lot, but being 6.75”, it doesn’t move a lot of air. Some have modified the housing to fit an 8” sub. I think there is a whole thread on updating the B&O system, so I suggest looking there for more info.
I’m going to look into that, but me thinks even a bigger magnet, better built sub would help the cause. For a bit over $100 on Amazon it’s not a bank breaking endeavor if it doesn’t improve much.
Clump
Charlie
Felton, DE
Bronco Heritage
It was really easy, but I've been messing with car audio for a long time.
This post tells you what to get for the front- https://www.bronco6g.com/forum/threads/audio-solution-under-1k.78024/#post-1995653
There's a bunch of videos on youtube showing how to replace the dash and pod speakers. The connectors mentioned in the link above make the dash plug and play. You can but connectors (without the bass blockers) from the same ebay seller for the pods.
If you don't have them get a set of plastic trim tools.
Lately people have been removing the bass blockers from the dash, but I'm completely happy with mine.
Broncobren
Matt
WT High Pkg MIC Mod Bumper
What size self tapping screws do I need for the sub?
Broncobren
Matt
Just finished and took top off for the first time. Still need to get Forscan done by someone local.
TTUHoopsFans
Bill
Frisco, Texas
2023 Ford Bronco
Nice. I still haven’t fully taken my top off yet and I’ve had it 6 months. I still need to assemble my top lift pro.
Broncobren
Matt
Had mine two months. Would love to get a lift, my top is just sitting on the garage floor for now 😐
Medic2586
Keith
South carolina
22 Bronco Big Bend Sasquatch
Does anyone have the “fake amp/sub enclosure” for a four door they want to sell? I would really like to have one to use for a project.
lalnx
Jon
Iowa
Titan, Rav4, had a 76 Bronco
ok, I have looked through this, looking for an answer on forscan rear pod configurations. I have 4" Kickers in the rear pods, and the fusion amp/6.75" sub. I saw this question asked, but it was not answered, So I will try it.
RagnorKon suggests
For passenger rear pod, set to tweeter, driver rear set to tweeter & Sub
so, for ACM field 727-01-01 XXXX-16XX-XXXX
with the 4" rear kickers being coaxial would it be bad to set as passenger rear pod to Speaker & Tweeter and driver rear pod to Speaker, Tweeter, & Sub?
so, for ACM field 727-01-01 XXXX-2AXX-XXXX
is the Speaker Tweeter Sub option more suited for the rear pods only if you upgrade to the larger enclosures/speakers?
regardless I will be turning the EQ off
Thanks
Mscdman
P
Denver
OBX
LOL I had the exact same failure of that plastic weld (1 of 3 that hold an extra mounting piece on the inside panel). Also used JB Weld to fix it. :)
I did open the fake amp. There is a circuit board inside that the input and output connectors are soldered to, but the circuit board has no components. Totally useless.
What are these plastic welds you speak of? Are they on the 2-door as well? I don’t see this in the diagram…
DarthLincoln
Chuck
Northern California - Contra Costa County
1999 BMW M coupe, 2023 Ford Bronco Badlands 2dr
yes it’s on the 2-door - mine is a 2-door.
What I’m referring to is an added plastic bracket that is plastic-welded to the inside of the passenger rear side panel. It’s located just behind the 12V socket and cargo light. This added bracket holds one of the blue clips that secures the panel to the body structure.
Several people, including me, had this bracket detach from the panel when pulling the panel free from the body structure. There are 3 plastic welds that can fail. You just need some epoxy like JB Weld to glue the bracket back onto the panel.
@dingle87 took some pictures of it. Here is the panel with that added bracket outlined in red:
Ford Bronco Fake sub/amp...Now what? IMG_5642
Mscdman
P
Denver
OBX
I see. Thanks. I bought a 20 inch long panel removal tool. I wonder if it’s possible to pry this blue clip off without breaking the plastic welds. The idea of glueing a brand new factory panel is not ideal…
did anyone find what replacement clip this blue clip uses? I’d like to have some on hand
