Fake engine sound disable
MGF
CA
Bronco Raptor, Merc AMG C63S, Range Rover Sport PHEV, BMW 328i
All Braptors, F150s, etc. through 2026 have ESE enabled from the factory. You can hear it with your radio off. To me the down shifts in sport mode when driving aggressive are a lot more pronounced with fake engine sound - that’s how I verify when I’ve turned it off.
KreeHBronco
Kevin
Bay area California
2026 Badland 4-dr Manual
I wish Ford would add an ESE control option to their on-board software that could be accessed via the touch screen settings menu. Besides Enable/Disable it could include a volume control and maybe even a section of GOAT modes where it was used.
stom_m3
Steven
2026 BRaptor on the way!
Can anyone confirm whether the 2025 Bronco Raptor has fake or enhanced engine sound enabled?
I'm curious about this as well. I have a '26 and just turned it off. That said, I don't think it had it to begin with. I haven't driven it since the change. But will report back when I do.
MGF
CA
2026 Bronco Raptors definitely have it. You can tell mostly when up and down-shifting in sport mode and the engine noise is exaggerated with all the windows up. I did before and after testing after toggling ACM 727-01-01
stom_m3
Steven
ok. Good to know. I’ll try it in the different modes.
stom_m3
Steven
So I got more time with the ESE turned off. It may be just me, but it seems that I now hear more bass than previous. It’s both more robust and goes lower in frequency.
One other question. Did you turn off ANC in the DSP module?
DSP 783-01-01, *xxx-xxxx-xxxx
Enable (D) Disable (C) ANC (Active Noise Cancellation)
MGF
CA
I did not turn off ANC
