Fake engine sound disable
MGF
CA
Bronco Raptor, Merc AMG C63S, Range Rover Sport PHEV, BMW 328i
All Braptors, F150s, etc. through 2026 have ESE enabled from the factory. You can hear it with your radio off. To me the down shifts in sport mode when driving aggressive are a lot more pronounced with fake engine sound - that’s how I verify when I’ve turned it off.
KreeHBronco
Kevin
Bay area California
2026 Badland 4-dr Manual
I wish Ford would add an ESE control option to their on-board software that could be accessed via the touch screen settings menu. Besides Enable/Disable it could include a volume control and maybe even a section of GOAT modes where it was used.
stom_m3
Steven
2026 BRaptor on the way!
Can anyone confirm whether the 2025 Bronco Raptor has fake or enhanced engine sound enabled?
I'm curious about this as well. I have a '26 and just turned it off. That said, I don't think it had it to begin with. I haven't driven it since the change. But will report back when I do.
MGF
CA
2026 Bronco Raptors definitely have it. You can tell mostly when up and down-shifting in sport mode and the engine noise is exaggerated with all the windows up. I did before and after testing after toggling ACM 727-01-01
stom_m3
Steven
ok. Good to know. I’ll try it in the different modes.
stom_m3
Steven
So I got more time with the ESE turned off. It may be just me, but it seems that I now hear more bass than previous. It’s both more robust and goes lower in frequency.
One other question. Did you turn off ANC in the DSP module?
DSP 783-01-01, *xxx-xxxx-xxxx
Enable (D) Disable (C) ANC (Active Noise Cancellation)
MGF
CA
I did not turn off ANC
KreeHBronco
Kevin
Bay area California
So it sounds like the Forscan code location to turn on/off ESE is different if you have the Lux package vs not having the Lux package. Is this correct? From what I have read in this thread the followings seems to be the settings needed. If I am wrong, please feel free to correct.
For non-Lux packages:
ACM 727-01-01, xxxx-xxxx-0xxx where 0 is ESE off and 1 is ESE on
For Lux packages:
DSP 783-01-01, *xxx-xxxx-xxxx where Enable (D) Disable (C) ANC (Active Noise Cancellation)
The one thing that concerns me on the DSP, is I want to keep the active noise cancellation but just eliminate the fake engine sound. Maybe leave the DSP along and just try the ACM non-Lux
stom_m3
Steven
So it sounds like the Forscan code location to turn on/off ESE is different if you have the Lux package vs not having the Lux package. Is this correct? From what I have read in this thread the followings seems to be the settings needed. If I am wrong, please feel free to correct. I did run this throw Chatgpt and it seemed to agree.
For Lux packages:
Those are two different changes. The ESE is the fake engine sound. The DSP is for noise cancellation. I turned off the ESE and have not tried toggling the ANC yet.
KreeHBronco
Kevin
Bay area California
Yes, thank you! I realized that and edited my post. I will only try the ACM mod first. Hopefully it will work on all models.
KreeHBronco
Kevin
Bay area California
For Lux packages:
So I finally made this change using Forscan for my 2026 4-dr Badlands with Lux.
My initial setting for ACM 727-01-01 was "30FF FCFS 1060" and I modified it to "30FF FCFS 0060" but after I performed a write all the value changed to "30FF FCFS 0050". Not sure why the 6 change to a 5, but I performed it multiple times.
For ACM, I could only find the "AS-BUILT" format so that is what I modified and saved. On my test drive I noted no difference between ECO and Sport (before Sport was louder), engine noise seemed quieter, and the engine sound I could hear was coming from the back of the vehicle (I just installed a Steeda muffler and it's a bit louder than stock) vs full immersion from the sound system. I didn't bother with the DSP ANC setting, as I want to keep it if it helps with road noise. I am happy.
