Factory Subwoofer works sometimes- help!
Hunter05
Willis, Tx
2023 2 Door Bronco
I just traded in my 2023 big bend. It had the subwoofer delete. I received my new 2023 black diamond last week. About one out of three times that I start it and drive it, the factory subwoofer is not playing. if I turn the bronco off and turn it back on, the subwoofer plays with the music. It’s going to the dealership later this week, but I was just wondering if anybody else has experienced this. I cringe at the thought of them Pulling interior panels to try to find the problem. Less than 200 miles on the new rig. Thanks for your time.
soldier989
Brett
Ohio
2023 Bronco Base MT / 2021 MX-5 GT / 1966 Ford F10
I had to install a factory 2023 into my 2023 with the sub delete. Its been installed for about 2 months now and has not had this occur a single time. I'm unsure if you have the base 7 speaker or the B&O, but with either setup, maybe you could try doing a master reset or reseat the fuse. Just some ideas before having the dealer do their damage.
B-Dog15
Brandon
Covington, Ky
2025 Base 4-Door
Reviving this thread to see if you ever found a solution? Mine does this every once in a while just wondering of there is a known cause/fix.
23OBX2.7
AB Canada
2023 Bronco
My B&O amp signal to my sub amp acted up randomly today so I disconnected the battery for ten min and fixed.
Worth a try also get your battery tested could be an old one that will mess many things up.
Disconnecting battery solves a lot of issues haha.
I've seen this before and the cause was a failing sub amp.
I've also seen it where people have used the Fusion sub amp (and some aftermarket ones), and the remote turn on from the Bronco is only 5V, but the Fusion amp needed 12, so a relay was needed on the remote turn on signal to make it consistent. Crutchfield has a relay just for this purpose - they call it a "trigger module"
23OBX2.7
AB Canada
2023 Bronco
Mine acted up agoin cooincefentialy as Ford is badgering me for software update for csm srems likebthey are usinf anddroid tricks to force updates
B-Dog15
Brandon
Covington, Ky
2025 Base 4-Door
This was gonna be my next try. I went into the tone settings and “reset” them and it hasn’t acted up since so I’m hoping it was a weird glitch that foxed itself.
B-Dog15
Brandon
Covington, Ky
2025 Base 4-Door
Was the failing sub amp from an aftermarket amp or the stock one?
If I recall stock - the thread would be around here somewhere
B-Dog15
Brandon
Covington, Ky
2025 Base 4-Door
Well fingers crossed I fixed it and don’t have to do any more digging on the topic. So far so good though!
23OBX2.7
AB Canada
2023 Bronco
Mine majically solved itself....
