Factory holes in the muffler?
Quatermain
Idaho
2025 Bronco
While I was installing a trailer hitch on my '25 Badlands I noticed two, apparently factory, 1/8 inch holes in the bottom. Each is about 6 inches in from the outlet and inlet and at the gravity bottom of the muffler. There is some obvious carbon streaking as shown. All I can think of is that they are drain holes to facilitate drainage from the muffler after wading? ideas?
Ford Bronco Factory holes in the muffler? Muffler2
dpAtlanta
North of Atlanta
2024 Badlands & 2019 GT350
Interestingly, if you wedge a potato in the tail pipe, all of the exhaust comes out the two holes. And if you floor it, you can actually get the Bronco to hover about 6 inches off the ground.
POTATO DISCLAIMER
This is complete SARCASM.
Thatguylegit69
Zachary
2023 Bronco & 2012 Ford Raptor
POTATO DISCLAIMER
Floor it for 20 minutes, or until potatoe is golden brown @ 350°.
Pops
North of Seattle
2025 2-door, Sas, Mid Pkg.
Dang it.
I thought those were interior heater vents that were missing air lines into the rear cargo area. I repaired it last month.
o_O
Thatguylegit69
Zachary
Dang it.
o_O
Reduce, Reuse, Recycle. Good for thinkin' Green!
VAtruck
Drainage holes, mostly for condensation.
Yup. The manufacturers only recently started doing that . In the old days you had to drill a low point drainage hole yourself. Actually had a mechanic fail me once for that as a "leak in the exhaust."
dpAtlanta
North of Atlanta
My new Ranger Raptor only has one hole... and the hole is much smaller in diameter.
I don't think it will hover like the Bronco, the Raptor also weighs 700 lbs. more and only has one hole.
