Factory D-Rings for Cargo Area?
niki
Dallas
'21 BD Samsquantch
This is probably a stupid question, but I still haven't found them. Searching the forum and the Googles with various versions of "d-ring" and "tie down anchor" has turned up nothing.
Can someone please link me to the factory d-rings that go in the (4-door) interior cargo space? They seem to be a sort of proprietary shape to flip up with those plastic finishing pieces in place.
JJustice
Greeneville, Tn
ā€˜22 Bronco
Do you have a mat in the back? I do, and it originally covered the rings. But the Ford mat also includes markings on the bottom so you can cut & expose the rings.
niki
Dallas
'21 BD Samsquantch
I do have a mat in the back. The threads for the plates to mount the cargo floor are exposed. I just don't have the hardware to attach there.
Bee Bop
Shane
Temple GA
21 Bronco Badlands, 02 Mustang GT Vert, 91 S10
New or used Bronco?
JimmyG
Greg
Ann Arbor, Michigan
Fords and Cadillacs
Bee Bop
Shane
Temple GA
Here are the tie downs. They are not too bad price wise. I am sure Leviton or Ruxters has them cheaper.
Search Catalog Results for parts.ford.com
Ford Bronco Factory D-Rings for Cargo Area? 1693858996369
Looks Like you will need the following:
Qty 4 Tie Down Hook Part #: M2DZ78550A74A $38.23
Qty 4 Tie Down Hook Cover Part #: M2DZ78313A68AA $10.22
Qty 8 Tie Down Hook Screw
Screw And Washer. Fuel Pump Module Bolt - M8 X 20mm, Driver. Part #: W706027S439 $13.50
niki
Dallas
'21 BD Samsquantch
THANK YOU SO MUCH. I was stumped.
Bee Bop
Shane
Temple GA
Hope you do not need the load floor. It is 400-600 for the carpet one and 600-700 for the vinyl one.
mattymik
Houston, TX
2019 Honda Odyssey, 2023 WildTrak
This thread seems like as good a place as any to get an answer:
I’m looking for longer bolts threaded the same as the ones for the tie downs. I went to Lowes and got them sized as M8, but the M8 bolt I bought isn’t fitting. It seems almost like the threading is different?
can anyone advise? I need an extra 0.5-0.75ā€ of length for the bolt to hold a sheet of plywood down
thanks
thanks
There are usually 2 different styles of thread for each bolt size - a coarse thread and a fine thread.
m8-1.25 (coarse) vs m8-1.0 (fine)
You probably just need the other thread pitch - Bronco bolts and most others are m8-1.25, but that isn't a universal given.
BigHoof
PA
Ram 2500
thanks
Sounds like you probably got the correct bolt size but the wrong pitch thread. Coarse is 1.25, fine is 1. Take one of your old bolts with you to compare.
mattymik
Houston, TX
Thats super helpful. Thanks guys. That’s gotta be exactly the issue.
