Exterior mirror courtesy lights
Jb7
Woodstock ga.
Ram 1500 sport
Noticed on underside of my mid package side mirrors there is a square plug insert. Is it possible to easily add the courtesy lights that illuminate under the mirrors as you walk up at night? Is the wiring there and it just needs a light and possible forscan? Anyone else notice these?
MN_OuterBanks
AW
Minnesota
2015 F150 SuperCrew
My guess is the wiring harness doesn’t include the wire for the puddle lamps. That’s a guess on my part based on previous experience replacing a mirror on a previous Ford.
MN_OuterBanks
AW
Minnesota
2015 F150 SuperCrew
Aren't they ditch spots rather than courtesy lights?
No lights on exterior outside mirror are spots. Lights under mirrors are puddle lamps to light ground as you unlock and open the vehicle at night.
Michael Grasso
Indianapolis
2025 Ford Bronco
Depending on your package, you can get Ditch Spots on the mirrors. They are switched on from inside and operate at slow speeds.
as shown below, underneath are puddle lights, to the side are the spot / ditch.
Ford Bronco Exterior mirror courtesy lights 0C771313-6E26-4361-B846-72182B27F63C
swooshdave
Portland, Oregon
Mustang
I don't think the lights on the sides of the mirrors are spots, aren't they just turn signals? I could be wrong.
Michael Grasso
Indianapolis
2025 Ford Bronco
Nope, they are switchable LED spots. High package or above.
Ford Bronco Exterior mirror courtesy lights 0D35A6F8-2AC6-4D1B-A209-237BC038E269_1_201_a
ZackDanger
Z
Massachusetts
2021 Toyota 4Runner
MN_OuterBanks
AW
Minnesota
2015 F150 SuperCrew
They are not turn signals, they are spots
Natai
Sean
Sacramento
Nissan Sentra, Mercedes GLC
Wondering if the 'at low speeds' limitation can be adjusted via FORscan.
jsharpe
www.sharpe.com
Prius
But if I manually turn them on and off repeatedly I could get them to look like white turn signals. ;)
Sorry, that's just the 12 year old in me leaking to the surface while I wait indefinitely for my Bronco......
Michael Grasso
Indianapolis
2025 Ford Bronco
Seems like a company already has a harness for the F150 that does it.
WuNgUn
Ontario Canada
2 door Squatched
I remember my 2002 SVT Focus... The door lock switches weren't illuminated like the window switches. Turns out, the switches ACTUALLY had LED's in them... Ford just decided to save some money, not to wire them in. In Europe, they were illuminated. 🤷
Ford does a LOT of annoying, cost cutting shit
