Mirror lights for the Bronco?
peta8368
Norwalk, CA
2016 Polaris Slingshot
anyone seen any mirror lights for the Bronco yet? Perhaps something similar to the Oracle?
I don't particularly like having a square light pod near the cowl, and with the mirror whistling on the non camera side mirrors, an aftermarket housing with lighting would address both at the same time.
Has anyone spoke with any vendors and know anything in the works? Thank you!
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
So you won't really get any whistling you'll notice with pillar lights installed.
One thing you could do is install some Baja Designs S1 lights (small) or Diode Dynamics SSC1 lights (again small) over there. Baja Designs sells rock lights which are very low profile that you could wire up there as well. Small, compact, throw off a great amount of light.
Baja Designs S1: https://www.4x4truckleds.com/led-auxiliary-lights/baja-designs/s1/
Ford Bronco Mirror lights for the Bronco? 1630552371213
Ford Bronco Mirror lights for the Bronco? 1630552376291
Diode Dynamics SSC1: https://www.4x4truckleds.com/led-auxiliary-lights/diode-dynamics/
Ford Bronco Mirror lights for the Bronco? 1630552422869
Ford Bronco Mirror lights for the Bronco? 1630552430450
Baja Designs Rock Lights: https://www.4x4truckleds.com/led-rock-lights/
Ford Bronco Mirror lights for the Bronco? 1630552457408
Ford Bronco Mirror lights for the Bronco? 1630552462751
peta8368
peta8368
Norwalk, CA
peta8368
peta8368
Norwalk, CA
Daktari
Oliver
these might be my first mod and one of the few I have in mind.
