Exhaust sound
gbub
Gary
Costa Mesa CA
2002 Ford Ranger FX4, 1969 Fairlane Cobra, 1970 2800CS BMW, 1961 Austin Healey S
I have only had my 24 Badlands a little over a week and find the exhaust is pretty quite until I step on it some. I know Ford has added artificial interior exhaust sound to some of their vehicles. Is Bronco one that has that? I hope not, I want to hear the real exhaust note not some artificial sound.
865Bronco
Robert
Knoxville
AMB Badsquatch, Land Rover LR3, Ford F-150
I added a Fast Intentions axle back exhaust on mine and it helps it sound better. It’s not a v8, never will be but I don’t think it sounds too bad for a 6
gbub
gbub
Gary
Costa Mesa CA
Right now. I don't plan to get an after market exhaust. If what I am hearing is the real exhaust, that is fine with me.
I just have the standard sound system in my Bronco. I didn't even know a Bang & Olufsen sound system was available for the Bronco. So does that mean I don't have fake engine noise?
Badlands Traveler
Mojave Desert
Ford F150 XTL 4x4 2019. Bronco Badlands Sasquatch
All 2024 Badlands to my knowledge have the fake engine noise. My Badlands has it too. if it’s stock and sounds like a hot rod, it has the fake exhaust noise pumped in.
SierraBronco
You realllly don't want to hear what the ecoboost actually sounds like 😆
I refered to my first two raptors as electric lawnmowers. That is that they sounded like after turning off the fake engine noise with forscan. Current rappy isn't bad because I was able to use forscan to make it always start in quiet mode.
RagnarKon
Bryan
New England
Ford Bronco, Escape, Focus
Correct.
All 2024 Broncos have it. For 2021-2023, only the Lux-packaged Broncos have it.
gbub
gbub
Gary
Costa Mesa CA
Well that sucks. I suspected that the first time I stomped on it a little. Now, I have to purchase Forscan to eliminate that fake sound.
Thanks for clearing that up.
65CarryAll
IL
The last 2 door Blazer (ZR2)
If you like the sound and can't tell if it's real or enhanced Ford did a good job. Might as well leave it.
gbub
gbub
Gary
Costa Mesa CA
Actually, I don't like the sound and knowing it is fake makes me dislike it more. Some may like the fake noise, I don't see any reason for it. If I want to hear the exhaust, I will install an after market system and listen to the real thing.
B22-2023
Houston
Correct.
My 2023 Mid package Wildtrak - with a major aftermarket audio system upgrade - had it. Sounded like heavy breathing out of my sub every time the right pedal mashed down. Probably because of my DSP and crossovers. Anyway after all other necessary Forscan audio mods, I did FENG last week - using the info you and a few others posted, which worked perfect. I switched it off then on then off again - then listened each time - just to make sure.
My 2.7 is modified end to end so its exhaust sound matches the performance which is great. The last step in that was an AFE cat-back, and replacing that kit’s puny muffler with the Roush.
gbub
gbub
Gary
Costa Mesa CA
I discovered something about the fake exhaust noise. If I put the GOAT selector in ECO mode the obnoxious fake exhaust sound goes away or at least is minimized. I don't particularly care for the shift strategy, but not having to listen to the fake exhaust it worth putting up with it. Plus, I do get a little better gas mileage.
Chapito
Laredo, TX
2023 Bronco Wildtrak
You can turn this off in forscan… the fake engine noise is very noticeable.
GI_Jo_Nathan
Jonathan
My stock base manual 2.3L exhaust is very quiet. So much so that I'm giving some thought to a mild aftermarket exhaust, to better hear what the engine is doing for shifting, and to clear up some space behind the rear axle.
I did the same for the same reasons.
I'm really happy with the Borla Climber Touring cat-back. Not cheap, but well worth it.
gbub
gbub
Gary
Costa Mesa CA
I don't have Forscan yet, so ECO mode will have to do for now.
