- First Name
- Jack
- Joined
- Aug 18, 2020
- Threads
- 2
- Messages
- 424
- Reaction score
- 932
- Location
- Temple, NH
- Vehicle(s)
- 2013 VW Jetta TDI, 2016 F350 4WD Crew Cab
- Your Bronco Model
- Heritage
i have a diesel VW Jetta and an F350 PowerStroke. Both are parked outside throughout the winter in New Hampshire. Both start fine at temps below -15°F. With the right oil for expected winter temperatures a block heater is only of significant value with temps below -20°F.I questioned whether or not I would need it and decided probably not, but I know I would use it if i had it. So, I ultimately decided to get it. It's not very expensive and I plan to keep the Bronco until I run it into the ground so it's just one less thing I will have to add if I ever do need it. The only time you "have to" use it is below 5 degrees Fahrenheit (-15 C) and even then, you will be fine unless it is much, much colder. It just helps reduce wear and tear on cold starts.
