Engine Block Heater value?
tyrobronco
CC
Central Florida
2021 Bronco,2017 Ford Fusion Energi
Hey Hive Mind -
I did search the forums and couldn't find a sustained conversation about the Engine Block Heater.
From my limited understanding:
Pro: Heating up the engine before driving helps it run more efficient
Faster to get heat on
Gets oil moving
Con: $100
For now, I do live in Florida (unneeded 99.7% of the time) but do plan on driving in the north/west where snow does happen (1% of the time over the first 3 years of ownership).
Is this option worth getting? Do I get the cord with it or do they just put the heater inside and it is another $60-100 for the cord?
Thanks for sharing you knowledge.
Montana Bronco
Montana
Chevy
I live in Montana, use it a lot.
Cord ?? What are You talking about ?? You mean an extension cord, yeah you need it. Buy it at Home Depot.
mrxg78
G
Cheshire, CT
FJ
Hey Hive Mind -
Gets oil moving
Con: $100
I agree that you don’t need it.
I lived in Boston for five years, with wind chills in below 0F and never had to use it. ( full disclosure not sure when exactly I would/should use it).
As for the engine oil. As long as you don’t drive her a couple of miles in sub freezing temperatures every day the oil will do its job.
Enjoy
Hey19
JJ
Bethlehem
You can get less expensive heaters aftermarket if a hundy is too much.
amccue90
Andrew
Illinois
2021 Badlands
M&M Beer
Marty
Ford Edge-F-150 Supercrew
Hey Hive Mind -
Gets oil moving
Con: $100
Waste of money even in Michigan
BroncoBuckaroo
Missouri
2017GT350-SOLD, 2013 Ford Edge, 1969 Torino Cobra
Here is a 2019-20 Ranger Block heater if you buy it through parts
Ford Bronco Engine Block Heater value? IMG_2539
OhhhhhhSnap
Elan
CO
06 Pathfinder, 04 F150, 14 CRV. 22 BD Bronco
I live in Colorado never used it. Even when I lived in the mountains for 20 years. Even if you do get it you can't just hop in and go, the rest of the drive train needs to be warmed up.
Skip it.
amccue90
Andrew
Illinois
2021 Badlands
mac62989
CT
2020 Tacoma Sport Access Cab, 2001 Trans AM WS6
Living in the Northeast and always parking my vehicles in a garage I'll probably never need it. For $100 will I add it just in case I ever might need it? Yes. I do think its overkill for FL though but its only $100..
Dral97
Ford Bronco, Wrangler YJ and 392, BMW 4 series
Skip it.
This. You either plug it in overnight or have it hooked up to a timer a few hours before starting. It’s not like a few minutes to warm ā€˜er up sorta thing. And ya still have to let it idle to warm up the rest.
If you don’t live in that type of environment that needs it, it’s just some forgotten accessory that doesn’t add any resale value imo. Now like someone said, Montana, Canada, Alaska? Sure, I’ll bet it rocks to have it in those places.
