Engine Block Heater Plug Location??
jwoobs
Detroit
Cool will ot work on 110/20v?
Seems like tje owners manual says 220/30v confusing
I went and looked up the owner's manual, and it looks like you are correct, it says 220V.
However, it also says it uses about 1kWh per hour, or 1kW on average. A standard 10-amp 110V circuit should be able to deliver that power.
Also, this image from Stackexchange shows that it is definitely a 110V plug, not any of the 240 only designs.
EDIT: Being the inquisitive idiot that I am, and with the engine still warm-ish from my lunch run, I took an ohm-meter to it. ~35 ohms, which would draw about 3.1 amps or about 350W on 110V.
Maybe tonight after it has cooled down I'll take another reading to see what peak current would be.
Ford Bronco Engine Block Heater Plug Location?? 1634836029131
Ford Bronco Engine Block Heater Plug Location?? 1634835917685
Khayze427
Hayes
Valley Forge, PA
Jeep JKU
Thank you!!! I have to say, I hate that location. I live in northern Wisconsin and will be plugging in my Bronco for 4-5 months each year. Having to open the hood seems so inconvenient. Thanks, again.
Run and zip tie a short extension cord from front of grill to the plug. Also tape the block heater plug/extension cord connection and get a cover for the plug end of the extension cord sticking out of the front grill.
Ford Bronco Engine Block Heater Plug Location?? 5E1EA30C-E19C-4B88-8D32-84DFC07F01C9
GiveItaTri
GiveItaTri
Robert
WI
F150, Big Bend
Thanks. I'll probably do something just like this.
zombie
New Brunswick, Canada
Just wrap your extension cord around your side mirrors, that's how people in Manitoba do it... because it gets so cold there that there are block heater plugs at most office parking lots.
(I wish I were kidding)
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
Thanks for the pic @jwoobs
So, this is strange. I called the dealer this afternoon to get one of these ordered so I can get it installed when I bring it in for an oil change in a couple of weeks. He ran my VIN and stated that it should already be installed. Just checked - it's not there. Or at least the cord isn't. Parts Salesman said perhaps I just need the cord. So, I need to get under the truck and see if I see the heater itself plugged into the block. Wouldn't that be strange?
Is this a Factory installed upgrade or DIO? Do you know @flip
If it was on the original order - would it be on the window sticker?
flip
Phil
IN
www.ruxerparts.com
Fords
F! Shoot me your VIN again, can't find it. I can look up in HVBOM.
redone17
Cold Spring, NY
So, why/how is this thing $100 when ordered with your build, but $350 when ordered from parts counter?
GJ7Z-6A051-B - $115
MB3Z-6B018-C - $240
Ford Bronco Engine Block Heater Plug Location?? B02C990C-4E30-4728-B14E-F297009A33E0
Ford Bronco Engine Block Heater Plug Location?? 0289721B-B4F5-47F0-A4D0-50556D6C00DA
GiveItaTri
GiveItaTri
Robert
WI
F150, Big Bend
GJ7Z-6A051-B - $115
MB3Z-6B018-C - $240
I've learned the parts department charges a lot more parts. The brush bar is $300 as an option but $500 when ordered over the counter. Floor mats are the same way. I used Ford Points to buy them and they were $30 more at the dealer.
Bronco6Geo
Florence, NY
'25 4DR Bronco Badlands Sasquatch HOSS 3.0
Mounted up inside the pass. side fender, right behind and above the headlight.
Standard 3-prong.
There is a rubber cap that is attached to protect the plug from spray and stuff. you can see it hanging down in this photo.
Thanks so much! My online Bronco manual was not helpful.
Bronco6Geo
Florence, NY
GJ7Z-6A051-B - $115
MB3Z-6B018-C - $240
There's no exterior plug with how it comes from the factory.
redone17
Cold Spring, NY
What do you mean? Factory comes with those two parts. The heater and cord. Plug just hangs under the hood.
I plan on mounting it to the bumper with a Noco Port Plug.
pcoriginal
Pablo
2022 Ford Bronco
    • Remove and discard the bolt.
    • Separate the steering shaft and position aside.
  1. If equipped, disconnect the block heater wiring harness electrical connector and retainers.
  1. NOTE: Automatic transmission shown, manual transmission similar.
    • If equipped, disconnect the block heater wiring harness retainers from transmission.
    • If equipped, disconnect the block heater wiring harness retainer from the RH side transmission stud bolt.
  1. If equipped, disconnect the block heater wiring harness retainer from the RH side of engine block and position aside.
What engine is this for? It doesn't look like the 2.7 in my Bronco.
flip
Phil
IN
www.ruxerparts.com
Fords
Block Heater
Removal
NOTE:
Removal steps in this procedure may contain installation details.
  1. Drain the cooling system.
    Refer to: Engine Cooling System Draining, Vacuum Filling and Bleeding (303-03B Engine Cooling - 2.7L EcoBoost (238kW/324PS), General Procedures).
  1. LH side only.
    Remove the fender splash shield.
    Refer to: Fender Splash Shield (501-02 Front End Body Panels, Removal and Installation).
  1. NOTE: Do not allow the steering column to rotate while the steering column shaft is disconnected or damage to the steering column internal sensor may result.
    Using a holding device, hold the steering wheel in the straight-ahead position.
  1. Remove the engine rear undershield.
    Refer to: Engine Rear Undershield (501-02 Front End Body Panels, Removal and Installation).
  1. Ford Bronco {thread} {filename}
    WARNING: Do not reuse steering column shaft bolts. This may result in fastener failure and steering column shaft detachment or loss of steering control. Failure to follow this instruction may result in serious injury to vehicle occupant(s).
    NOTICE: Do not allow the steering wheel to rotate while the steering column shaft is disconnected or damage to the clockspring may result.
    1. Remove and discard the steering column shaft coupler retainer.
      Torque: 22 lb.ft (30 Nm)
    1. Separate the lower steering column shaft from the steering gear.
  1. NOTE: Access the block heater from the inner fender well.
    NOTE: Make sure the block heater wiring is routed and secured away from rotating or hot components.
    Disconnect the block heater electrical connector.
  1. Remove the block heater.
    Torque: 41 lb.ft (55 Nm)
Installation
  1. To install, reverse the removal procedure.
  1. Fill and bleed the cooling system.
