Enable Cornering Fog Lights on Bronco with Modular Bumper via Forscan?
Kach Vartan
Los Angeles
Sedan
I'm trying your way, so not working at first. I will keep a watch on it. Does it only work at night?
So here’s what I think is happening with the “Fog, DRL and Cornering” setting I enabled.
1. If lights are fully turned off, can’t turn on fogs and cornering isn’t activated.
2. If parking lamps are turned on, fogs can be manually turned on/off, but cornering isn’t available.
3. If auto-headlamps are turned on and it’s in DRL mode, the fogs automatically turn on and can’t be turned off as far as I can tell. I think this is because of the DRL feature I enabled.
4. If main headlights are on (either automatically or manually), then fogs can be manually turned on and off enabled and, when not turned on, cornering works.
In short, the cornering feature is working when the main lights are on. I’m going to try disabling the DRL feature to see if cornering works in DRL mode. I don’t think much of a use case in that scenario. And not sure I’m a fan of the fogs being on during the day with no ability to turn off. If I really need them, I can either switch to parking lamps or full headlights and manually turn on.
I should mention I was in Drive the whole time while testing. Not sure if that is relevant or if all of this should be the same in Park or Reverse. Also, I forgot to check what happens when I activate the turn signals. Will report back later.
mlugb6ro
Monte
2d Rubicon, escalade
I just tested mine. Being in drive was the key. It looks to be working perfect. Is there a situation you would like me to test? I'm not sure what DRL is.
Kach Vartan
Los Angeles
Sedan
I just tested again. Everything (cornering and turn signal activation) seems to work as long as I’m in Drive, Reverse or Neutral and the main lights are on.
If you didn’t enable the DRL feature, I’ be curious if you can still turn on the fogs in that mode (or if cornering or turn signal activation). I’m going to disable the DRL feature as I don’t want the fogs on constantly during the day.
mlugb6ro
Monte
I set it just as you laid out. The fogs are not coming on with out me pressing the button.
Does DRL mean the transmission is in drive?
mlugb6ro
Monte
Thanks for letting me know it has to be in drive. Looks to be working now.
Kach Vartan
Los Angeles
Sedan
DRL is referring to Daytime Running Lights. I have the light switch set to auto and had pull out of my garage for the main headlights to turn off. When I do that and car is in drive, neutral or reverse,, the fogs automatically turn on and can’t be turned off.
mlugb6ro
Monte
Yep, I just tested. Same for me. I played around with the settings some but couldn't stop the fogs from coming on with the DRL. I can live with that.
mlugb6ro
Monte
This may be working after a quick test.
mlugb6ro
Monte
I would love to find an easy way to connect wheel well lights that I have to these fog lights now that they work with the turn signal and turning angle. They are currently using aux switches.
mvilla
San Francisco
4-door Badlands Bronco w/ Sasquatch package
Do you have the gatekeeper knucklepods? If so, can you record a video if you get this working? Thinking about doing that and would love to see it in action!
mlugb6ro
Monte
mlugb6ro
Monte
I got this working using these, since I don't like altering the factory wiring.
https://www.amazon.com/dp/B00TXRWOPA?psc=1&ref=ppx_yo2ov_dt_b_product_details and this https://www.amazon.com/dp/B07MLPBPW5?psc=1&ref=ppx_yo2ov_dt_b_product_details .
Sorry no video. It took about 2 hours on my back removing 6 or 7 screws on each side to access the fog plugs. A couple are hard to get to. Faster for someone younger than 70. I love how this is working for me with these lights. https://www.bronco6g.com/forum/thre...signals-or-turn-your-wheel.85821/post-2127105 . Here is a video a part of which shows how to access the fog light.
