Electric Side Steps installed
BlueBronco
DFW
For what it is worth, the Rockslide Engineering steps use a similar magnet type switch and I have not had a problem with them accidently deploying while off-roading over some fairly large rocks. However, my magnet switch is mounted on the door sill (see red circle below) and they include a rocker switch (red light by the kick panel) to disable the steps if needed.
Ford Bronco Electric Side Steps installed 1643233182260
ColbyLang
Colby
Louisiana
2017 Sierra Denali
Reason I’m looking for them is to cover the pinch weld between the body of the truck and the factory boards that came on our OBX. I can put Ford’s Body Armor, but can’t re-mount factory boards if we do that. Hate seeing the weld between the rocker panel and the running board. Hopefully they cover this completely when folded. They don’t cover it 100% on Jeeps
kahunabob
Bob
Santa Clarita, CA
4runner
I had rockslide engineering sides on my Jeep. They are beefy! They are really designed to take a hit on the rocks! But...I am going amp research on my Bronco (when they are released). The reason for amp research? The RSE steps stick out pretty far on the side of the vehicle. I am looking for a more discreet look and I do not plan to run my bronco on the rocks. Also, the RSE I had on my jeep needed to be constantly reset. I had a LJ (2 door). The RSE steps would deploy 99.99% of the time as expected when the driver's door would open. But on the passenger door...they would only deploy about 80% of the time (requiring a reset). It may be because the passenger side was not used on a regular basis? RSE did not have an explanation for me...wanted me to purchase a new module...really? On $2K plus steps!
Lastly, the set on my Jeep made a loud 'clunking' sound when they closed. Other than that they were great. I like how the Amp Research tuck under and cover the seams on the bottom of the bromco.
BLMike
N. California
Jeep Ultimate Wrangler and two other normal cars
What I am gathering from this thread is that if you want electric steps do Amp or the OPs solution once they find out manufacture of step. If you want electric steps AND sliders, do RSE?
kahunabob
Bob
Santa Clarita, CA
4runner
I agree with your statement. 100%
IwannaGOfast
Jon
Brea, CA
1991 Ranger Long Travel, 2014 Cruze Commuter
BlueBronco
DFW
I have the factory Amp Research steps on my F150 and the RSE's on my Bronco and would offer up the following pros/cons
RSE Pros:
1. Functional rock rail/slider
2. Provide protection from rocks thrown from front tires
3. Protection from p-lot door dings (unless parked next to jacked up bro dozer)
4. Rail acts as a static step
RSE cons:
1. Make a ka-chunk noise when closing
2. Have to be reset every so often (a matter of toggling the switch on/off)
3. Pricey
4. Step seems flimsy but is very rigid
5. Knock off version available for cheaper that is not rock rail rated
Amp research pros:
1. Quieter
2. Clean look
3. Larger step
4. Well built looking
Amp research cons:
1. Not a rock rail / slider
2. No protection from rocks door dings
3. Probably gonna be pricey (although OP's version are cheaper)
uae247
Shihab
UAE
2021 Cactus Grey Bronco Badlands 4 door Sasquatch
I just checked and it is a Chinese manufacturer. The dealer does not have a name just said a Chinese brand 🙄.
From my experience with my wrangler JL, never had an issue and they are pretty quiet.
RSE look to bulky to me and I don't like the shape of the step. Other option would be to get the Bronco Raptor side steps and call it a day.
kahunabob
Bob
Santa Clarita, CA
4runner
RSE Pros:
RSE cons:
3. Pricey
Amp research pros:
1. Quieter
2. Clean look
3. Larger step
Amp research cons:
I think you hit all of the points.
I thought I got a bad batch with the resetting, but it looks like you have to reset your RSE every now and then. Also, the powder coating on my set were getting bad after a couple of years. A lot sooner then expected. I powder coat stuff all the time, usually stays pretty pristine unless it is damaged.
How is the powder coat holding up on your RSE?
Giordiesel
Frank
New Hampshire
2019 Ford Ranger
[/QUOTE]
I like Raptor Side Steps as well, they look like a regular rock rail with a bolt on step... perfect, take 'em off when you need to, I wonder when they'll be available?
hollapm
Paul
SoCal
2021 Bronco First Edition, 2021 Ranger, 2024 F250
If anyone finds a way to read the CAN bus, or tap into the Amp controller that would be super helpful. The ranger controller may work for the bronco, (amp said that ranger and bronco are same adapter). I don't like the magnetic switches and would love a more factory integration!
puckett_jw
Middle GA
'22 F250 Tremor
I have the RSE on my Bronco (https://www.bronco6g.com/forum/threads/installed-rock-slide-engineering-step-slider.43841/) & the AMP's on my F250, and I completely agree with BlueBronco's assessment. All-in-all, the AMP boards are definitely more "polished". They are a step first & foremost, whereas the RSE is a rockslide first & a step second.
I am glad to have the extended coverage from flying rocks that the RSE provides. I have only had them installed for about 2 weeks & I don't drive my bronco much (really don't drive much with all of the WFH stuff & it being a spare/fun vehicle), but I have had 0 issues having to reset my boards.
The other feature/option that the RSE has that I am not sure about the AMP is that I have the door delete kit, so there is an easy-to-access button to extend the steps under the seats, so when you have the doors off, you have manual access to the steps. I would check to see if the AMP's have something like that.
LikeToTurnLeft
Matt
Phoenix
2015 Ford Transit Connect & 2007 F150 XLT
I’m going with AMPs on our Badlands. I had them on my Ram for over 15 years and never had a single issue. I don’t care about it not being a full blown rock slider. I’ll never get my Bronco that crazy rock crawling. Plus, I love the clean look of the AMPs. The RSE steps are bad ass though.
Richterman
Badlands, Superduty
RSE are beefy. You can have 2 steps they way they stick out. Which can be helpful if you have a rack. Also they prevent some of the rocks flying from the tires from hitting the door and getting paint chips. RSE all the way
puckett_jw
Middle GA
'22 F250 Tremor
They are beefy. I got the optional skids too, so that doubles the steel.
