Eibach Pro Truck Stage 2 Spring Selection
ThunderFlash
Doug
Washington
'24 4-dr WT, '22 2-dr WT, '15 Explorer Sport, '02 F250 SD V-10
Short story: if you're on the fence AT ALL between the standard or HD Eibach springs for PT Stage 2s, I'd encourage starting with the HD spring.
Longer story: I started with a used 2-door '22 WT (V6/10 speed auto STD) with HOSS 2.0 suspension. I swapped to the Eibach Pro Truck Stage 2 after adding weight with ADD Rockfighter bumpers, full SFR skids, M8000 winch, RCI slider/steps, TrailRax rack & side pax, DIY rear seat delete/cargo deck, lights, etc. I only wanted 1" of lift over stock as I plan on staying with 35" rubber, but I may want to try 37s later. I ended up picking the HD spring for the front since most of the added weight was over the front axle and standard spring rear. The OEM rear Bilsteins also seemed to be on the harsher side of ideal to me, and I didn't want that.
Well, it was not a great setup. Noticable side to side and front/back body motion. There was significant jacking/sinking in the rear when shifting/accelerating/braking. Panic stops felt like a stopie with the rear hanging in the air. Corners were unsettling to some degree depending on the situation. I also bottomed the rear out on mild bumps with moderate loads at low to moderate speeds.
This week I swapped to the HD spring in the rear and it was a significant improvement in ride and handling both on the road and on the trail. The truck is much, much more composed in every way. I could carry more speed with more weight through rough stuff and didn't bottom out at all. I also think the stiffened rear is forcing the front to flex a bit more.
I had wondered if I should have just beefed up the springs on the Bilsteins, but I am now very happy with my switch to the Eibachs.
I currently have the doors, roof, and rack off, but will update if anything changes when this center of gravity raising weight goes back on the Bronco in the fall.
There can be a lot of truck to truck variation and also personal preferences, but if you're at all on the fence on which spring to option on your personal coilovers, I'd recommend going to the HD spring first. They are not stiff or harsh at all.
Note: the springs have not settled in completely yet, but I expect I'll have more lift with them, too. I lowered the perches about 1/2" when the HD spring went on and the rear still came out about 3/4" higher than with the standard spring.
Ford Bronco Eibach Pro Truck Stage 2 Spring Selection PXL_20250727_040959027
Ford Bronco Eibach Pro Truck Stage 2 Spring Selection PXL_20250727_040904970
Ford Bronco Eibach Pro Truck Stage 2 Spring Selection PXL_20250723_213109432
Ford Bronco Eibach Pro Truck Stage 2 Spring Selection PXL_20250726_232753408
Ford Bronco Eibach Pro Truck Stage 2 Spring Selection PXL_20250726_232826486.MP
Ford Bronco Eibach Pro Truck Stage 2 Spring Selection PXL_20250727_003153879
Ford Bronco Eibach Pro Truck Stage 2 Spring Selection PXL_20250724_202246392
TLO
Canada
youtube.com
2 door
Thanks for the write up and pix...
I definitely want to go with HD springs on the Eibachs. I have an overland build l, 2 door Heritage...and it's too heavy for the stock suspension.
From what I've read,I was worried they didn't have enough damping compared to the Bilsteins, but if you're not bottoming, then I'm satisfied.
Ford Bronco Eibach Pro Truck Stage 2 Spring Selection 1000019175
ThunderFlash
ThunderFlash
Doug
Washington
Ooo, man....that roof top tent and a bunch of gear might overwhelm them. I feel like I could use a SLIGHTLY heavier spring even now anticipating the return of the doors, roof, and rack.
Yeah, the dampening is a bit slow now, but I like the soft feeling of that extra half wave form.
I suspect the larger diameter Bilsteins and beefy spring might be better for that. What are they, 6100s or something?
NC_Oak
2024 4 door 2.3 sasq
100% get the HD springs. The eibachs are valved super soft, so as long as you have a little weight on your ride the HD springs are THE correct choice
TLO
Canada
youtube.com
2 door
No, she's running the stock Sasquatch Bilsteins. I want the extra spring AND get back the ride height I lost.
The tent is a Foothill...maybe 110Lbs. Not crazy.
I travel as light as possible. 😁
TLO
Canada
youtube.com
2 door
See, that comment makes me feel like they're going to bottom and top out hard, regardless of the spring.
That or be bouncy like a pickup truck 🤔😯
ThunderFlash
ThunderFlash
Doug
Washington
Yeah, but it's high above the roll center axis. It may have too much leverage. My rack with side packs alone is about 100 pounds and I feel it for sure. I think the beefier 2.5" body Bilstein +HD spring upgrade might be better. I think they are adjustable, but it's a clip/groove deal, so you have to pull the shock to adjust the height.
Hopefully someone here with experience will chime in.
  • Like
Reactions: TLO
