Easy bolt replacement for hardtops
j_marinelli
Spring Branch, TX.
Lazerus
Sean
Las Vegas, NV
Wrangler JL. Land Rover Discovery Sport
I use the GPCA's on my Wrangler and would recommend them to anyone who plans on regularly removing their hard top.
I remove/replace mine regularly, depending on the weather, and find them to be faster/easier than using the ratchet. The handles have held up through quite a bit of use - but I have had to replace the thin rubber washer with a thicker, more durable set of plumbing washers from Lowe's.
That they also double as tie downs is an added bonus.
Portapot
Maryland
Cj7, RX350, f250,
Thanks I just ordered a set!
MayhemMike
Mercury
Um, who at Team Bronco never thought these should be standard?
wrbix
VA and FL
LR Def90, F250 7.3, Caterham 7, LR Series III, etc
Second thread on this subject - also be aware that McMaster Carr has a variety of knobbed M8 bolts that’d work. Colors, comfort grip, etc.
Boxer4
TRUCK
These look good but you might want to consider the torque settings. Someone just posted about their rear glass strut snapping off. We really don't know how fragile the MICs are.
"To install, reverse the removal procedure. Torque the fasteners that secure the rear roof panel to your vehicle to 15 ± 2 lb.ft (20 ± 3 Nm). "
" Note: Do not overtighten the fasteners. You can strip the fasteners if they are overtightened."
BigFootie
Wisconsin
The Amazon of the business world!
BigFootie
Wisconsin
So are you are saying using my 1/2in drive 18v Milwaukee impact driver might be overkill? :cool:
wrbix
VA and FL
No not really…..never have quality issues with McM-C; do, not infrequently, with A-dot-com.
McMaster-Carr: the source of all things useful, Man-Cards required for entry.
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
BigFootie
Wisconsin
No not really…..never have quality issues with McM-C, do, not infrequently, with A-dot-com.
McMaster-Carr the source of all things useful, Man-Cards required for entry.
I use mmc all the time. You are correct, not the cheapest, but almost always next day delivery but also not for free. But as a business user, mmc is awesome.
tjnoffy
Jay
Maryland
'21 Bronco OBX Sas, '22 Escape Hybrid, 2 Harleys
j_marinelli
Spring Branch, TX.
Isn't that pretty much what these are?
Similar but the ones I show are fixed without movement and the ones you show can move.
