- Joined
- Mar 17, 2022
- Threads
- 85
- Messages
- 235
- Reaction score
- 441
- Location
- Riverside, California
- Website
- dv8offroad.com
- Vehicle(s)
- Bronco's & Jeep's
- Your Bronco Model
- Badlands
- Thread starter
- #1
WE'VE RELEASED OUR FIRST 3 BRONCO FRONT BUMPERS
We begin our series with three front bumpers, all with unique features & style. The MTO Series Bronco Front Winch Bumper, the OE Plus Series Low-Profile Bronco Front Bumper, and the newest incarnation of our popular FS-15 Series Winch Front Bumper, Bronco Edition. We've also designed an adaptive cruise control relocation bracket, for use when installing aftermarket front bumpers on Broncos that have ACC.
2021+ FORD BRONCO | MTO SERIES WINCH FRONT BUMPER
The DV8 Offroad MTO (Made to Overland) Series Bumper is a Winch-Ready Front Bumper for the 2021+ Ford Bronco, and is compatible with all trim levels. Manufactured from high-grade steel, the MTO Series retains the factory sensors, has a 3-inch pod light mount towards each side, and mesh inserts that can be painted. There is an optional bolt-on bull bar that can mount a 13-inch LED light bar to supplement your lighting.
The winch mounting point was designed to sit within the bumper, and is accessible through two openings at the top of the bumper. It can mount up to a 12,000 lb. winch. If you're not running a winch, you can install a single row 20-inch light bar instead. It would sit protected behind the perforated aluminum accent panels. The Adaptive Cruise Control sensor module must be relocated if Bronco is equipped with an ACC system. Our ACC Relocation Bracket is sold separately
Key Features:
• Optional Bull Bar Light Bar Mount
• (2) 3” Pod Light Mounts
• 2-Stage Powder Coating
• 4mm Body and 5mm Mounts/Supports
• In-Bumper Winch Mount
• Reinforced D-Ring Mounts
• Compatible with Factory Plastic and Metal Skid Plates
• Works with Factory Parking Sensors
• Paintable Aluminum Mesh Panels
2021+ FORD BRONCO | OE PLUS SERIES WINCH FRONT BUMPER
The Bronco OE Plus is a Low-Profile Front Bumper for the 2021-2022 Ford Bronco. This was designed to fit the form of the Bronco as tight as the OEM bumper. The front panel was designed to match the grille of the higher-tier trim levels, although it looks excellent with the lower-tier trim levels as well. Behind this cutaway pattern, a Dual Row 20-inch LED light bar can mounted. It features pod light mounts on each side of the bumper, that fit 2 pods each.
Key Features:
• 20" Dual Row Light Bar Mount
• (4) 3” Pod Light Mounts
• Does Not Interfere with 360° Camera
2021+ FORD BRONCO | FS-15 SERIES WINCH FRONT BUMPER
The Bronco FS-15 is a 2021-2022 Ford Bronco Winch-Ready Mid-Width Front Bumper, with the option to include modular wings to make it a full-width bumper. The light mount tabs on the bull bar can be oriented to mount a 13-inch light bar above or below the bull bar. Up to a 12,000 lb. winch can be mounted on top of the bumper. At the center of the bumper, either a 20-inch dual row light bar or 6 pod lights can be mounted.
Two recovery mounts that take 3/4" D-rings provide additional recovery options. This bumper is compatible with the OEM plastic & metal skid plates, and also retains the factory parking sensors.
Key Features:
• Optional Full-Width Wings
• Adjustable Bull Bar Light Tabs
• Winch Ready
Visit https://dv8offroad.com/pages/ford-bronco-bumpers-and-accessories to shop all of our Ford Bronco Parts and Accessories.
Plus... use code "ForumMember" at checkout for 10% off!
