- Mar 17, 2022
- 83
- 224
- 400
- Riverside, California
- Website
- dv8offroad.com
- Bronco's & Jeep's
- Badlands
The DV8 Bronco Front Skid Plate was designed to work with both the original OEM bumpers or our aftermarket Bronco bumpers. If your Bronco has the factory plastic skid plate, this is the perfect upgrade to maximize the protection to the front undercarriage. It also protects the sway bar disconnect on the Badlands and First Edition trims. Made from 3.5mm Steel Plates & 5mm Steel Supports, it can handle anything the trail throws at you!
Key Features:
Key Features:
- Micro-Texture Black Powder Coat
- Protects Front Underbody
- Constructed from 3.5mm Steel Plates & 5mm Steel Supports
- Paintable Aluminum Mesh Inserts
- Easy Bolt-On Installation
- Fitment: Direct Fit
- Material: 3.5mm Steel Plates & 5mm Steel Supports
- Fits OEM Plastic Bumpers: Yes
- Fits OEM Metal Bumpers: Yes
- Fits DV8 Bumpers: Yes
Visit https://dv8offroad.com/pages/ford-bronco-bumpers-and-accessories to shop all of our Ford Bronco Parts and Accessories.
Plus... use code "ForumMember" at checkout for 10% off!
