- Mar 17, 2022
- 83
- 224
- 400
- Riverside, California
- Website
- dv8offroad.com
- Bronco's & Jeep's
- Badlands
2021-22 FORD BRONCO | FRONT LOWER CONTROL ARM SKID PLATES
DV8 Offroad’s A-Arm Skid Plate for the 2021+ Bronco was designed to protect the aluminum front, lower control arms from rocks and other obstacles on the trail. Made from 3.5mm steel and finished in a micro-texture black powder coat, it also shields the vulnerable shock bolts from damage. Couple this with our Front Skid Plate and fully protect the front undercarriage of your Bronco while running those rocky trails you love.
These skid plates have an easy bolt-on installation and are compatible with all 2-Door & 4-Door Bronco trims, including Sasquatch & non-Sasquatch package equipped vehicles.
You can check it out here: https://dv8offroad.com/products/bronco-a-arm-skid-plate
Key Features:
- Sold as a Pair
- 3.5mm Steel Construction
- Micro-Texture Black Powder Coat Finish
- Protects A-Arm & Factory Shock Bolts
- Bolt-on Installation & Hardware is Included
- Fitment: Direct Fit Bolt-on
- Finish: Micro Texture Black Powder Coat
- Material: Steel
- Material Thickness: 3.5mm
- Weight: 25lbs/pair
- Sasquatch Compatible: Yes
Visit https://dv8offroad.com/pages/ford-bronco-bumpers-and-accessories to shop all of our Ford Bronco Parts and Accessories.
Plus... use code "ForumMember" at checkout for 10% off!
