DV8 Offroad | Competition Series Front Bumper
DV8offroad
Riverside, California
dv8offroad.com
Bronco's & Jeep's
The DV8 Offroad Competition Series Bronco Front Bumper was CAD designed by an off-road desert racing driver and is the lowest profile bumper in our line. Its prerunner-style design offers superior protection extending from the front of the Bronco to the differential. The included steel skid plate serves as a direct replacement to the OEM plastic or metal skid, and features bolt-on side gussets for extra engine protection. The Comp Series provides an improved approach angle over the stock front bumper & skid.
This was constructed using 1.5mm & 3mm steel tubing with 3.5mm steel plates for maximum weight reduction without sacrificing protection. At the center of the bumper is a paintable aluminum mesh panel that provides improved airflow to the intercooler. There are inset light mounts for two 3-inch LED light pods and one 20-inch dual row LED light bar to provide supplemental lighting off-road. The bumper has mounting holes for the front parking sensors, and we provide plugs for models that lack the feature. Adaptive Cruise Control equipped Broncos require our ACC Relocation Bracket to retain functionality.
Key Features:
  • Includes a Steel Skid Plate with Side Gussets
  • Low-Profile Fitment with Improved Approach Angle
  • Lightweight Design Providing Ample Protection
  • Tube & Plate Steel Construction
  • Micro-Texture Black Powder Coat Finish
  • Mounts for (2) 3” LED Pod Lights
  • Mount for 20” Dual Row LED Light Bar
  • Integrated Front Parking Sensor Mounts
  • Simple Bolt-On Installation
**Please Note: This bumper is not compatible with the factory plastic or steel skid plate. We’ve designed a special replacement steel skid plate with side gussets that is included with this bumper.
Check it out here: https://dv8offroad.com/products/6th-gen-bronco-rear-shock-guard-skids
Technical Specifications:
  • Fitment: Cutting only required on plastic bumper skid plate mounts/D-ring mounts
  • Material: 3.5mm Steel plate, 3mm/1.5mm tube
  • Finish: Micro-Texture Black Powder Coat
  • Weight: ≈ 59 lbs
  • Utilizes Factory Hardware: Yes
  • Fits Factory Skid Plate: No
  • Fits Factory Fog Lights: No
  • Fits Adaptive Cruise Control: Yes with ABBR-01
  • Minor Wiring Required for Lights
Visit https://dv8offroad.com/pages/ford-bronco-bumpers-and-accessories to shop all of our Ford Bronco Parts and Accessories.
Plus... use code "ForumMember" at checkout for 10% off!
Big Diamond
Miles
Atlanta, GA
2022 Bronco HOSS 3.0 Wildtrak
Looks really good!
This looks great and is priced well, IMO
Question:
Can the Pod lights be wired to the factory fog connections or will it need to be wired to an aux switch?
Matador
Dallas TX
Kia Optima, Toyota Supra, palisade
This so awesome looking, if could pair it with the Lobo hidden winch skid plate, I would be all over this.
usmc_joe
FL
Ford Bronco
just picked up this bumper along with the rear. Can't wait to install.
DV8offroad
DV8offroad
dv8offroad.com
Bronco's & Jeep's
Awesome man, we need to see those final result pictures! 🤩
mdk77
BM
Illinois
Bronco Base SAS
I just purchased this bumper and can't wait to install. For those who installed I have some questions:
- Do I really need to cut off the tow hooks or can I just remove?
- Is there any option to add shackle hooks to this bumper later?
- I bought the lights and wiring harnesses and I have a base with plastic bumper. I have aux so will be wiring it all to the aux switches. If there are any tips here I would welcome them
- I looked and couldn't find any good install videos on the install of this bumper. Does anyone know of any available?
Thanks much all
One who waits long time
Jack
Oregon
F250 Diesel, Road Glide Ultra, Fat Boy, Beta 500 R
do they make a similar rear bumper?
Brent
Omaha, NE
2023 Bronco Black Diamond
Thanks much all
Any update on your install?
mdk77
BM
Illinois
Bronco Base SAS
