DV8 Offroad | Capable Bumper Front License Plate Mount
DV8offroad
Riverside, California
dv8offroad.com
Bronco's & Jeep's
2021-2023 FORD BRONCO | CAPABLE BUMPER FRONT LICENSE PLATE MOUNT
This Bronco Front License Plate Mount relocates your plate at the center of your bumper and out of the way of the grille. This allows for maximum airflow to the engine compartment. It was designed to be located in a more aesthetic position, giving a full view of the OEM Capable Steel Bumper. We recommend taking a few minutes to remove the bracket when running a moderate to difficult trail. The bracket was finished in a micro-texture black powder coat, and features a simple bolt-on installation.
* Please Note: This ONLY fits the OEM Capable Steel Bumper. This Does Not Fit the HD Modular Steel or Plastic Bumpers
Check out the Capable Bumper Front License Plate Mount here: https://dv8offroad.com/products/bronco-capable-bumper-license-plate-mount
Key Features:
  • Fits the Factory Capable Steel Front Bumper ONLY. This Does Not Fit the HD Modular Steel or Plastic Bumpers
  • Relocates License Plate Below the Grille
  • Allows Maximum Airflow to the Engine
  • Recommended to Remove on Moderate or More Difficult Trails
  • Removes in Minutes for Trail Use
  • Does not Interfere with Fog Lights
  • Micro-Texture Black Powder Coat Finish
  • Easy Bolt-On Install Utilizing Factory Hardware
Visit https://dv8offroad.com/pages/ford-bronco-bumpers-and-accessories to shop all of our Ford Bronco Parts and Accessories.
Plus... use code "ForumMember" at checkout for 10% off!
Dquimby9
Dan
Henry
Tundra
Love it, if I hadn't just installed a bracket I made at home using the same mounting points I would buy this!
JTA
VA
Toyota Sequoia
Just received mine. Will update once I have had a chance to install.
userdude
Jared
Denton, TX
2023 2dr Badsquatch
If you off road, you guaranteed to squash this thing like a beer can. I did! (Technically I have the one that's like a skeleton of this one). I also crunched the rear mod plastic holder. It'll happen!
I still would get another, just deciding if I want to just throw the (now mangled) front license in the rear and plead forbearance from Mr. Police Officer if I get pinched for it. (My brother has warned me! lol) Definitely the only one I liked that I found.
Kevin Scarbel
Everglades
Kevin
Chesapeake, VA
2024 Bronco Everglades 4dr
Everglades
Installed today. The mounting holes are slightly off sideways so it isn't quite centered.
I had to completely remove one bolt. Had their design been on the mark, I wouldn't have had to. Anyway, more disappointed about it being impossible to center it due to the bolt cut-out slot location in the product being evidently off. Well-built Chinese market cardboard box though.
Footer
NJ
2023 Bronco
Love mine and easy install, completely centered.
