Dumb or brilliant idea for help removing top??
RYD003
Juan
Southern California
MY23 Bronco OB
Just saw that the top lift pro for the 2 door is delayed a bit.... so I thought what else can I try. Using an engine hoist? Rig something up to mount to the top of the hoist to go under the top and lift it up?? 🤔
Silver-Bolt
Eureka, MT
I did something similar to remove the cab of a 1956 Ford pickup I was working on. Attached some 2x4's to the engine hoist/cherry picker. It wasn't pretty but it sure did the job. I had the cab on and off by myself several times.
HoosierDaddy
__ Eric
NW. Indiana
The roll bar will foil your plans ... most likely.
Do you have a garage?
I rigged up a rope hoist and screwed around with cheap stuff until I just bought a proper Harken Hoist designed for doing this.
I have not installed it or had a chance to use it yet, but they have stellar reviews ... and a coworker has one, loves it.
https://www.harken.com/en/shop/garage-storage/hoister-storage-systems-75-200-lb-load10/
No garage?
Build a tall "swing set" / gantry crane if you have the room and can get away with it. Drive under it and lift it with some type of hoist system.
The taller the better.
My garage ceiling is around 11' and I need every inch of that for the hoist , top etc etc in order to drive out from under it.
https://www.amazon.com/Frame-Brackets-Complete-Mounting-Hardware/dp/B01M28VV0N
Ford Bronco Dumb or brilliant idea for help removing top?? 1679677856191
Ford Bronco Dumb or brilliant idea for help removing top?? 1679678078159
Ford Bronco Dumb or brilliant idea for help removing top?? 1679678113575
Fly
MA
Subaru Outback
Aman
Aman
Northern NJ
I received my 2 door Top Lift Pro two weeks ago, so they are definitely shipping. Try reaching out to customer service and ask what the lead time is for a new order.
RYD003
RYD003
Juan
Southern California
MY23 Bronco OB
That's about what I had in mind
swami37
Fort Lauderdale Florida
1950 Ford F-1 and 2020 F150 FX4
To those who have removed the 2dr hardtop: I have a very low ceiling in the garage, is it possible to lift the top a foot or so and slide backwards? I'm thinking of mounting the hoist on a track so this would be possible. I have 18.5" from the top of the hardtop to the ceiling.
https://www.bronco6g.com/forum/thre...ley-150-for-manual-or-200-for-electric.51708/
You only need to lift it about 4 inches to go back with it
there are some line up pins that need to clear when lifted then you can go straIght back with the top
Ford Bronco Dumb or brilliant idea for help removing top?? 1679680582907
cbrenthus
Western PA
'22 BadSquatch, '02 T/A
Is the 2 door hardtop any different than the 4 door? I thought they were the same, and that the only difference between the 2 door and 4 door hardtops is the 2 door is 3 pieces and the 4 door has the extra "targa top" over the second row?
I ask because I don't know why you would need a lift specifically for the 2 door?
Also, another thought is you could get a rear cross bar roof rack to lift with.
Wickedbronco
Jon
Chicago
I built something similar to remove my trans.
Ford Bronco Dumb or brilliant idea for help removing top?? 896547D8-41DD-4438-8B52-CEF913571464
Silver-Bolt
Eureka, MT
Look in the background and you can see what it looked like.
Ford Bronco Dumb or brilliant idea for help removing top?? fl2
RYD003
RYD003
Juan
Southern California
MY23 Bronco OB
It's getting there...
in the second pic you can see the holes at the ends of the 2x4s. Thoes will hold 3/4" pipes then another 2x4 on the other end to hold up the front of the top.
I will put this Part right behind the roll bar then stick the pipes in from the inside. Lift a few inches to clear the 2x4s and done!
Ford Bronco Dumb or brilliant idea for help removing top?? 3DA7D349-48CA-4CD9-B2CF-6878EFC08B85
Ford Bronco Dumb or brilliant idea for help removing top?? AF82B055-7CBB-4B15-80B1-58B206A6C27B
RYD003
RYD003
Juan
Southern California
MY23 Bronco OB
Prototype worked well enough Will make some design changes But I think this will save me $1000 as no need to buy the TopLiftPro
Ford Bronco Dumb or brilliant idea for help removing top?? CD2FB9A9-1519-4ABB-A057-92F18A9699C5
Ford Bronco Dumb or brilliant idea for help removing top?? CF1DFA24-C16E-40A7-8D1F-A459810FEEF5
Ixr
2022 2DR BASE SAS
Has anyone tried using a drywall lift and some straps to lift the top off?
