Dumb or brilliant idea for help removing top??
Fly
MA
Subaru Outback
I built a roof lift with a pice of electrical strut and some angle iron it bolts on in a min and I left my top off.
Do you have any pics of the angle iron piece that goes into the hardtop slot? Is it 90 degrees? I’d love to make a setup like this.
RYD003
RYD003
Juan
Southern California
MY23 Bronco OB
Change of plans With the addition of Jtops Bimini I could not easily use supports under the roof top, so I used some straps to hoist the roof from above...
Ford Bronco Dumb or brilliant idea for help removing top?? 06E712AE-2DDC-409D-8570-2D4FAF7E6EC9
Ford Bronco Dumb or brilliant idea for help removing top?? F2823D5F-0EAD-4962-AC92-38179EAC304B
Docindahouze
Doc
Cumming, GA
Ford Bronco
I’ve got try and install my trailrax roof rack with the pakrax. In order to do that I need to access the rear fender bolts in between the bottom of the rear clamshell and the rear fender. Is it possible to just prop rear clamshell up a couple of inches one side at a time so I have enough room to get to the bolts? Thanks. I’m trying to see if I can do this so I don’t have to ask for help to completely remove the rear clamshell.
RYD003
RYD003
Juan
Southern California
MY23 Bronco OB
Yes I think you can just prop up the rear. Stuff a rolled up towel between the roof and the roll bar.
huey
kevin
Ontario & Kentucky
VW GTI VW EOS GMC Envoy Badlands Bronco
I was wondering if an engine hoist would work
what hoist are you using?
RYD003
RYD003
Juan
Southern California
MY23 Bronco OB
It's a Pittsburg automotive 2ton crane from harbor freight
Ford Bronco Dumb or brilliant idea for help removing top?? 53A82D97-5F3E-4C5C-A16C-780C30614C35
Ford Bronco Dumb or brilliant idea for help removing top?? 651ABA16-082A-4E61-8EC9-8C43A94F8F72
huey
kevin
Ontario & Kentucky
Thanks! So glad to hear that cuz that is exactly what I was looking to buy
Bronkers
Ben
Las Vegas, NV
2022 2dr Bronco
Just saw that the top lift pro for the 2 door is delayed a bit.... so I thought what else can I try. Using an engine hoist? Rig something up to mount to the top of the hoist to go under the top and lift it up?? 🤔
4 eye bolts, 4 stubs of 2x4 (temporary spacers between clamshell and body), 4 of those little hardboard angle pieces they put around sharp angles in packaging sometimes (to protect the bottom edges where the straps have to slide), and 2 cam lever straps.
Practice. Carefully. <15min
Ford Bronco Dumb or brilliant idea for help removing top?? 20210815_173240
Notawrangler
AJ
2023 Ford Bronco Heritage Edition
I have this Lange original Gen2 lift left over from my Jeep sale. Hoping to be able to adapt to to lift my 4door Heritage top if it ever gets built. I would also like to store the doors on the bottom somehow. Any ideas would be appreciated.
Thanks
Ford Bronco Dumb or brilliant idea for help removing top?? EE770159-1BDD-4A2B-AA7C-E99EE71B0D64
Ford Bronco Dumb or brilliant idea for help removing top?? 0847ABDA-3F7F-4042-8E04-A0FC3C657DCF
Ford Bronco Dumb or brilliant idea for help removing top?? C1BDD75B-44EA-4E8F-9CC7-4E34876743F5
Ford Bronco Dumb or brilliant idea for help removing top?? B8F44674-A261-4364-AC47-97F4914F806A
