Duel Climate Control in a Base Bronco
Kyukidoeric
Panama City Beach Florida
2022 Bronco (former 69 & 77 Bronco owner)
Does anybody know if I can add duel climate control in a base 2022 Bronco? Maybe changing the control unit? Or is it more complicated than that?
Medic2586
Keith
South carolina
22 Bronco Big Bend Sasquatch
SEEMS TO BE SOME PROGRAMMING ISSUES. I bought one (came out of F150, same description, only had truck instead of bronco icon on button), put it in with no issues, came on and thought it was okay but it blew hot all the time.....has to be something that can be changed to make it work via forscan but so far, i haven't figured it out. hoping some one will soon cause i like the look....keep me updated if you find out anything.
Ducati1098
Totally different system. Changing the module would just be a small part of things that need to be changed.
You would need a whole new climate control housing at very least also and most likely a different wiring harness.
JohnnyBronco
Pennsylania
X4
Dual has separate heat/cool circuits at least inside the vehicle. And separate damper controls maybe even separate fans but maybe just dampers. Your best bet is scoring the entire center dash from a salvage unit
Stevdug
Tulsa
2022 base bronco
To the above comments. Yes and no. Yes it has been done in F150 models, I have done it in my mustang. No it will not be true dual control, but it is possible for it to hold cabin temorature. So far I have failed to get it to work in the bronco.
MNBigfoot
MN
I open or close a vent, works perfect.
‘21OBX
90Bronco19
2022 bronco outer banks
Not worth the effort works horrible anyway. On both our ‘21 and 22 it is horrid. I always have to set my side way below the desired temp. The wife will be 3* hotter and my dash vents will go to warm instead of keeping me at my set point. Has to be 5* or more to truly get one side to blow cool and other hot. My superduty and our Chevy blazer worked way better.
Kyukidoeric
Kyukidoeric
My wife runs the heater all the time, it almost burns my feet, I think anything is better than an argument everytime I turn off the heat. Does anybody have an answer if I can change out any components to achieve the duel AC?
Kyukidoeric
Kyukidoeric
That's what I'm afraid of.
