Door Rubbing on the Body
RubiconSasquatch
Josh
Denton, TX
2022 BadSquatch, 2021 JLUR, 2008 JK-X, 65 Elco
Seems like a grinder, flap wheel, and a little touch up paint should do the trick. Unless the other gaps on the door are all misaligned too, why would they be trying to move the whole door?
RebelRebel
Ashley
Idaho
Acura MDX
Yes they had to remove both the back doors and reposition them because they were completely out of alignment and then of course they have to redo the paint in all those areas.
j_anderson
Jason
Fort Wayne, IN
www.instagram.com
I've recently discovered I have some paint rubbed off on my driver side, 2D
DSRTR8D
Westland, MI
2020 Jeep Wrangler Willys Unlimited
This is it! Totally agree!
And for the folks talking about alignment, look, I live close to MAP and know someone who was putting on the doors at one time. He said the door either pops in place on installation or it doesn’t—no wiggle room there.
Now, maybe adjusting the strike plate / larching mechanism is the answer? But if not, grind and re-paint. Why take the time to remove the doors? Unless it’s misaligned to the point where there’s a line of paint removed from the bottom of the jamb and the door, I don’t think removal is the way to go. I’ve seen that happen with these, but the vast majority are the chip-in-the-corner issue.
jdawg
Julian
NewHampshire
Atlas/65Mustang
My rear door had to be shifted forward and up to be correctly aligned. Pretty sure just moving the latch/plate would not have fixed that. Fitment is subpar on these from my sample. Heck the hood doesn't even align with the fenders (not even bothering with that). Tell your buddy someone sucks at quality control.
Daktari
Oliver
my 4 door is going to the body shop tomorrow to get this (and one other paint issue) fixed. I went there last week to have them look at it and they might just try a rubber mallet or something to bend that low corner of the door out just a bit, I guess would have the same effect as the folded shop towels.
I'm fine with just touch up paint there, it's invisible enough that repainting more or less the entire door frame would be silly overkill IMO.
Hope they do a nice job, it's a body shop with a very good reputation that's been in business for decades, pretty sure they know what they're doing.
BaseSquatch
@NotOJsBronco
Nice! Mine is in the shop as we speak. They realigned the doors, and are fixing the paint entirely (the right way). Ford is also reimbursing me to get my ceramic coating redone. So overall, I’m pretty happy with how they are handling it!
omg_bbq
Eli
Oakland, CA
www.instagram.com
2022 EG BD SAS
Hey all, I created a thread about my problem before realizing this one existed. I have the problem described in this thread about the door corners. In addition to that though I have this long long line of paint missing from the bottom of the front doors. I'm assuming same problem but another location. Check your doors too!
Ford Bronco Door Rubbing on the Body tempImage4IFHz9
Hulk-2Dr
Lawrence
2022 Bronco 2DR 2.7L
Hi there! Send a private message to us with your VIN and the name & location of your Ford dealership, along with some more details about your situation. I’ll look into this for you. Thank you!
i just found out that i have the same issue on my drivers side door, the bottom of the door is rubbing against the rocker and paint scraped off. I added a rubber washer on the bottom hinge of the door and it helped a little. this is a short term solution. The bottom hinge looks like platic and tapered to easily accept the door.
Ford Bronco Door Rubbing on the Body IMG_9472
omg_bbq
Eli
Oakland, CA
www.instagram.com
2022 EG BD SAS
My truck just was in for this. Warrantied work 100%. Doors adjusted and repainted everywhere there was contact. Your mileage may vary but it’s worth a shot bringing it to your dealer.
akturbo
Seattle Eastside
What was the fix?
They sent it to a body shop to align the door and looks like they just used touch up paint to fix the paint damage.
Sharon82305
Sharon
MI
what dealer warrantied yours? I’ve been denied warranty repair by two dealerships for this same issue. First claim was April of 2022. Paint issue is a big problem now.
Ford Bronco Door Rubbing on the Body 102BE2C4-37CE-458B-815E-A9AD899A47EF
Ford Bronco Door Rubbing on the Body 165562FE-6B4D-462D-8192-298003EDEBF5
Ford Bronco Door Rubbing on the Body C3B54FA6-6820-4770-8BA3-6725D2B5C583
Ford Bronco Door Rubbing on the Body 6C156A27-391D-4D72-A8DB-723B9F2D6DC8
jdawg
Julian
NewHampshire
Atlas/65Mustang
My dealer did state that this is on Ford to fix. Unfortunately my dealer has not fully fixed it for me yet. Still happening. Going on the 3rd visit so far. Not sure if this would qualify my car for a lemon. You can go to any dealer. If that is an option, you should.
omg_bbq
Eli
Oakland, CA
www.instagram.com
2022 EG BD SAS
Yeah I forgot to mention in my DM to question asker that while my dealer did warranty it, and the body shop had it for a very very long time, they did not fix it, they just painted and tried to adjust the doors.
