Door pockets - least obtrusive?
solracarevir
Carlos
Puerto Rico
Bronco Black Diamond Sasquatch
Another vote for Bartac.
They bolt on to your door using the same mounting holes as the OEM net and yes, they might look bulky but since they are flexible if you rest your leg against them they are comfortable. Plus, did I mentioned they are big? You can really store a good amount of stuff in there.
Ford Bronco Door pockets - least obtrusive? 1774445808024-2m
Tonka Bronka
Duncansville
F350, V60 Polestar, 900SS, K1300S, RnineT Racer
Texas Complete Bronco. Are they the least obtrusive? Absolutely not! Are they US made and hold a ton? Yep. Do they hit my leg? Nope.
Dadsquatch
Brad
Chandler, AZ
2022 Ford Bronco
I see Bartact makes these ones as well, but I think these are just like they say “panels”. Meaning it’s completely flat so can’t store anything behind it or in it, unless you add a pouch or other accessory. Am I correct? Hard to tell from pics on website without seeing a pic in use on the door. Anyone have these ones?
https://www.bartact.com/products/br...21-bartact-pat-pending?variant=39977500999723
solracarevir
Carlos
Puerto Rico
Yes, they are completely flat, they are meant more like a molle attachment so you can add your own bags and stuff. Since they have no bolts at the top I guess you could slice some papers between the panel and the door but not really mean to be used as a storage area.
SlowTrak
NorCal
It's an SUV btw....
I use them, they are perfect and look like they came from the factory. No idea why Ford just used the super flimsy nets instead of something like this.
Before:
After (took about 1 minute to install)
I use these shorter ones for the front and the normal longer ones for the rear too. Went with shorter ones in the front since I keep a bottle of hand sanitizer in the front pocket for easy access/use.
