Angus Murphy
Georgia
2022 Bronco
I found this Door holder idea on the inter webs for a Jeep and decided to utilize the plans for my 4 door bronco.
4 - 10' X1" PVC pipe
 schedule 40
6-1" pipe insulators
 (black foam)
14 - 1" PVC elbows
10 - 1" PVC TEEs
1 - Can of PVC cement
Cut the pipe into 10 - 2 foot sections,
 8 - 4 inch sections,
and the rest into 1 foot sections. use the images above to copy the assembly. Message me for more info if you have questions.
Thanks for the great inspiration. My son needed a project for school and this worked perfect and got my doors off the floor.
Ford Bronco Door Holders Using PVC Pipe -- When Off vehicle 20220811_185544
bagsBronco22
Madison, NJ
Bronco Big Bend
I’m going fancy with mine and adding casters to the bottom t-connectors by stuffing a dowel in there and drilling a hole (7/16”).
Like this idea - going to have my son build as he loves this type of stuff. Do you have finished pictures? Did you just put wheels on the four corners or also in the middle?
mcon33
Central Illinois
2022 Jeep Willys Unlimited; 2022 Bronco BD SAS
Does this happen to fit in the back area? Like instead of bagging the doors up, would this work to hold the doors and keep them with the vehicle?
Tow it?
RedHotFuzz
2022 Bronco Black Diamond 4D
I'm making mine with 5 slots (4 for doors, 1 for the center roof panel) so I will likely add another set of casters. I'm almost finished - will post pics when I'm done.
E_Cups
Ed
Louisville, Ohio
My wife's Jeep Cherokee
Can anyone provide the necessary adjustments to the plans provided for a 2-door version of this cart? While I don't have the exact door measurements for the 2-door(waiting for build), I have to imagine they are a little longer than a 4=door. Thanks!
RedHotFuzz
I forgot to post a pic of my completed Deeeluxe model with integrated casters and 5 slots (one for the hardtop center panel).
Ford Bronco Door Holders Using PVC Pipe -- When Off vehicle F99A2574-3B48-41FC-8FD4-715A61A65783
E_Cups
Ed
Louisville, Ohio
Thank you sir. Yeah, if I see any issues with how they're secured to the dollies, I'll figure out a way to bolt them down. But so far so good.
Any hints on how to keep this "square" as you assemble it? Thanks
JimmyG
Greg
Ann Arbor, Michigan
Fords and Cadillacs
 schedule 40
 (black foam)
14 - 1" PVC elbows
10 - 1" PVC TEEs
You are a HERO! Awesome!
LETSGOBRANCO
Gary
Ohio
Has anyone been able to do a toplift copycat for the bronco? I've seen some jeep owners do it, I would assume it's generally the same.
Johnny Mo
Westchester County, NY
teachu2shoot.com
I made separate front/rear dollies for mine so that it would be easier to move around and keep the doors more protected within the confines of the PVC tubing. Trying to sort out how I want to incorporate my mid panel storage into my existing hoist setup. Excuse the mess in the garage.
Ford Bronco Door Holders Using PVC Pipe -- When Off vehicle PXL_20240515_112313711
Ford Bronco Door Holders Using PVC Pipe -- When Off vehicle PXL_20240326_015520701 (1)
Ford Bronco Door Holders Using PVC Pipe -- When Off vehicle PXL_20240515_112319475
