Does 1" require reprogramming?
DaddyO
Jules
Austin, Texas
2024 Bronco 4D 2.7L Sasquatch
On my ‘24 Badlands I went from 35’s to 37’s and went from 17 to 15 mpg running hiway speeds in Texas. In town getting 15mpg. I didn’t recalibrate my tire size and at 70 m/h am showing 74 on my gps. I have switched to monitoring my gps for speed but have to set a destination to use it.
jensht
Germany
2023 Ford Bronco
For what it's worth, the ABS and stability control are tied to the programmed tire size. So you may get premature or delayed reaction if you get yourself into a situation where either is triggered.
ABorges
Art
Fresno CA
1973 F100
I'd like to change the tires on my badlands to 285/75R17 which is about a 1" increase in diameter. I'm thinking that will be close enough to not require reprogramming as long as I don't mind a minor discrepancy in speedo readout. Can I get any agreement with, or an argument against, with my thinking?
If it is only 1" difference, your speedo will barely be off.
Dirtrider
Bruce
St. Louis
Honda Ridgeline, Super-C Motorhome
I might be halucinating but I thought the Badlands came stock with the 285/70 -17 tires (at least in '22, the year of my Black Diamond). Or maybe I'm having a senior moment. My Black Diamond came with 265/70-17 and I'll be going to the 285/70-17 which is as wide as I can go on the stock 7.5" wide rims. I'm not planning to reprogram for the larger tire size.
HPNQ420
Wauwatosa, WI
'23 Bronco, '19 GTI, '88 R100GS, HPN BMW G/S, 14 JK Rubicon
Same here. 1 mph difference.
i didn’t bother with reprogramming tire diameter.
so 70 mph on speedo is 71 actual mph.
Only difference on mine is i lost approximately 2 mpg
still love the change 😎😂
Actually a 2 mph difference. I am 99% sure that the digital speedometer is programmed to read 1 mph high over the calculated value. (I checked at a bunch of speeds.) So 70 mph on your speedometer is 69 mph calculated, 70 mph displayed, but 71 mph actual.
(EU regulations require the speedometer to read high. The instrument I have on my HPN BMW is from Germany and the +1 km/h is built into the open source firmware in its case.)
So the "built-in error" helps you with mild increases in tire size.
Reprogramming is easy if you care. Unnecessary if you don't.
Thanks, that's a better calculator than the one i was using. I'm not concerned with the slight speedo/odo error, I just worry about upsetting some of the electronic Voodoo on the Bronco
The voodoo only cares if you have a low or dying battery.
Or spin your tires excessively in 4wd
