Disabling the Remote Alarm Button on your remote Key
GoHack
Palmdale, CA
'25 Bronco, 2.3L 4-Cylinder, 7 Spd. Manual, 4 Door
Is there any way of disabling the Remote Alarm Button on your remote Key.
I have a problem w/mine always setting my alarm on my Bronco due to other things, and keys in my pocket hitting it, sadly at the wrong time of the day when people are sleeping.
If they had designed it better perhaps, having that switch more indented than the other buttons, that might have helped.
Why they even need it is beyond me. For locating your Bronco in a large parking lot, I would imagine, but then again, your vehicle will only stand out anyway.
Lcubed
l
UsA
VW golf r, 2023 ManBadSquatch
the cheap solution: take the other junk out of your pockets
Brisco2
2012 F350 XLT, 2018 Ford E350
In Forscan, you can switch the panic from one press to two. Have not set mine off since I switched
Fly by Nite
Walt
Pa
If you don't have easy access to Forscan, you can take the fob apart and put a piece of tape on the contact for the button.
GoHack
GoHack
Palmdale, CA
the cheap solution: take the other junk out of your pockets.
It doesn't take much to be in your pocket to make contact w/the Alarm Button.
GoHack
GoHack
Palmdale, CA
I've thought of doing that.
GoHack
GoHack
Palmdale, CA
Forscan is all you need, I disabled mine and its great.
BdyCM726-62-01x*xxxxxxxx--0=disabled, 1=2 clicks, 2=one click (default)
What is Forscan?
Fly by Nite
Walt
Pa
Lcubed
l
UsA
shift all the non-essential stuff to another pocket.
once i did that, the false alarms stopped.
super low tech and extremely easy to implement
GoHack
GoHack
Palmdale, CA
super low tech and extremely easy to implement.
I really don't have a whole lot of things in my pocket.
The real issue here is in the design of the button. It either needs to be more receded so that it's not as easy to contact, or simply removed or easily be deactivated.
Lcubed
l
UsA
Ford Bronco Disabling the Remote Alarm Button on your remote Key IMG_3711
are you using the dealer supplied key cover?
it was part of the SWAG i received at pickup
TheKim
Kim
That key cover reminds me of my grandpas flip phone carrying case.
Ford Bronco Disabling the Remote Alarm Button on your remote Key 1694616576190
Moto26
Tucson AZ
I don’t carry anything else in the pocket where I put the key, but I can set it off just leaning against the door sill, or my work bench, or any number of things.
My truck is even worse, and on top of that it has the old “switchblade” style key that pops out, and I hit that button all the damn time, which is really fun to have in your pocket because when it’s deployed it’s about 3 times longer than an old-fashioned car key.
Really, the best solution here is the double-click setting through Forscan.…
helifino16
Ron
Mount Sinai, NY (Long Island)
What is Forscan?
Well, it's like this...
It's the 🍆 part the doc takes off your baby boy's baby boy.
(couldn't resist - sorry)
