Diode dynamics OEM wiring harness for backlit SS3's
OffroadBandit
Georgia
Ford F-150
Hey all!
I think I'm going nuts, so hopefully someone here can steer me in the right direction.
Last year, in preparation for my Bronco (which is still not here) I purchased some SS3 Sport pods lights from diode dynamics. After doing more research on wiring strategies based on some posts and YouTube videos, I realized it would probably work best to use one of the wiring harnesses offered by diode rather than run my own wiring. After emailing back and forth with diode, explaining that I wanted to be able to control the backlights separate from the primary lights, I was recommended to purchase the OEM Auxiliary Switch Dual-Output 4-Pin Wiring Harness. Upon looking at the specifications on the site, it didn't seem that there was a separate power cable for the backlights to run on, but I assumed that the customer service rep knew more than me as to how their products would interact, and that there would be a way to control each set of lights individually with this harness.
I just received the harness, and for the life of me, I cannot understand how I could possibly have the backlights on without the primary lights being powered. It seems to me that the one power cable that runs parallel to the grounding wire powers both sets of lights. Am I supposed to remove the blue backlight wire from the 4-pin connector and run a separate power wire from the aux switch to those removed backlight wires? Does that then mean I need to run a separate grounding wire? What's the point of buying the harness if I need to do so much extra diy?
Thanks in advance for any advice you all can provide!
Links to the parts below:
https://www.diodedynamics.com/stage-series-3-sae-dot-white-sport-led-pod-pair.html
https://www.diodedynamics.com/oem-auxiliary-switch-dual-output-4-pin-wiring-harness.html
Gotdesl
Alan
Rifle, CO
2016 Ram 3500 Megacab 4x4
There are two separate wires, one from the back of each deutsch connector that needs to be run to a separate auxiliary switch lead. (Labeled D1 and D2 in the diagram that you linked) Tie those two wires together and hook them to one of the low amp pre-wired aux switches. The backloght leads have a spade connector as they come from the factory. I just wired in my SS5's and decided to leave the backlighting for a rainy day.
Girldadx3
Rocky
Expedition, Bronco
The red wire goes to aux switch wire to turn on main beams. The D1/D2 can be spliced together and go to second aux wire. That will control your backlight.
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
Where are your installing three? Pillar lights? Do you have upfitters?
OffroadBandit
OffroadBandit
Georgia
Ford F-150
This is what I was missing. Thank you! I knew it was something obvious I wasn't considering. Thanks for your time to respond!
Yeah, they're going on the pillars. I do have the switches from the factory on my build.
swanjonson
Peabody, MA
2007 Toyota FJ Cruiser, 2015 VW Golf SEL
I have a set of SS2 with backlighting, in my bumper. I am going to see if I can get the backlight to turn on when the parking lights come on.
Need to do a little digging into wiring diagrams.
4x4TruckLEDs.com
Adam
Lindenhurst, NY
OffroadBandit
OffroadBandit
Georgia
Ford F-150
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Nice! Thanks! That's perfect
Yeah it's why we held off offering SSC3 w/backlighting for the pillars. We were waiting on our harnesses to come in. Now that they are here, we offer the SS3 with or without back-lit for pillars
WldOne
Jillian
Chesapeake, VA
'21 Bronco OBX
Contact
Randy
Austin, Texas
Bronco Big Bend. FJ Cruiser
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Does this have an inline fuse and is it really necessary since the switches are connected to a fuse?
No there is no need for a fuse. The upfitters have a fuse
WSTP3
Tom
Bronco Wildtrak (2 door)
Chrome_Pony
Chrome
The Great Land
Backlit SS3s (and other pods) come with a short 3 wire pigtail with Deutsch Tech connectors. Red/Blue/Black. Literally all you need for an SS3 (or any backlit DD pod) install is just a length of wire and crimp/solder butt connectors.
The ground is already common for both backlight and main LEDs, so Black gets grounded. You wire the Red to the hero switch for the lights, and decide what you want to tap for the backlight to connect the Blue. Done.
