Daylight Sensor Sensitivity Adjustment
Topher
Christopher
Pasadena, CA
2023 4 door Outer Banks, Cactus Grey, MIC, LUX
Does anyone know of, in Forescan perhaps, there is a way to increase the sensitivity of the daylight sensor mounted on the dash?
I installed 3M Crystalline film to the windshield. It does a great job of cutting down the UV and IR rays but unfortunately it also causes the headlights to come on during the day. I would like the DRLs to be on during the day, so I don’t want to shut off the auto-headlight option.
Anyone have any thoughts?
Rosalieee
R
LA, CA
Raptor, BMW M3 Competition X-Drive
So far have not found a solution for this...not possible in forescan as far as I can tell because the sensor has a fixed impedance.
Topher
Topher
Christopher
Pasadena, CA
Ducati1098
There is no adjustability. I remember seeing a post on here a while ago of someone removing the top part of the sensor to bring in more light and it seemed to work for them. I can’t find the post though.
KABQ
Aaron
Albuquerque, NM
Now you have DRLs in the rear, too!
Daytime running taillights, if you will.
Mhguy
Greg
Reno, Nv
43’ motorhome, 14 Jeep jku toad, 2014 F150 toad
Maybe make a small aluminum foil 1/2 ring, short in the front , tapering up and over the back half of the sensor, kind of like a hood, to, go around the back 1/2 of the sensor, and up and over a small portion of the sensor, to reflect light into the sensor, just to see if something like that will work. This would be JUST A TEST, not a permanent solution!!
If it works, you could make something highly reflective to fit around the back of the sensor, that wouldn’t be too esthetically unattractive, for a more permanent solution.
Just an off the wall idea !!!
Topher
Topher
Christopher
Pasadena, CA
Interesting. Thank you.
