Kicker Key adjustment???
JB 208
JB
Minnesota
Big Bend Sasquatch
Hi all, I think I read this here but not sure. I installed the key 200.4 like a lot of folks. Went through the pink noise set up and everything passed but I still feel like there isn’t enough bass. I’m curious what folks set their gains too? Mine are basically straight up and down. I do have a powered sub on the way, which should solve a lot of the issue. Thanks for the help!
JB
RagnarKon
Bryan
New England
Ford Bronco, Escape, Focus
On my 200.4 the gain is at the lowest setting.
On the 500.1 that's feeding my subwoofer it's around the ~9:30 position.
22OBX
Bryan
Hartford, AL
JB
An amp isn’t going to add that much bass unless you have amp with a bass booster in which the key does not have. Even then any full range speaker will be limited in ability to produce real bass.. The key will only increase the volume and improve overall sound quality through the DSP. The only real way to improve bass is through a dedicated subwoofer and amplifier for sub.
KABQ
Aaron
Albuquerque, NM
I installed a powered sub under the seat this weekend. That's the solution - it's night and day.
Since I already had the Key pnp wiring harness, Plug n Play Kits was able to send me just an adapter harness for the sub instead of having to purchase the whole kit. Install was super easy!
JB 208
JB 208
JB
Minnesota
Big Bend Sasquatch
Ok, thank you.
where_are_the_AC_seats
Andy
New Orleans, Louisiana
Can I ask what powered sub under seat you used? I did the PNP kit without a sub or crossover, but my bass is terrible.
KABQ
Aaron
Albuquerque, NM
