ResidualGenius
Zach
Denver
Looking great!!
Natai
Natai
Sean
Sacramento
Nissan Sentra, Mercedes GLC
I love the idea of the stickers. Seeing the switch picture today, it looks like the application might be to cover the Aux X portion. The paddle might have a texture.
I noticed that too. Thinking I might just put them in front of the switch. Just inside the inset area.
DUSTYcazOREGON
Craig
2021 Ranger Tremor/2022 Bronco/2006 Dodge Charger
As seen in the Aux Switches and Accessory Rail thread, there's a lot of discussion about the aux switches. I came across a file someone created to make labels for the Gen2 Raptor switches and got to thinking about something similar for the Bronco. There are plenty of different labels out there you can by for upfitter switches, but I was thinking more of a Bronco style.
I've put together a few so far. Probably not the easiest to read, but it has the Bronco feel to it.
I'm also sticking with black and white, because my current plan is to print these on to glow-in-the-dark adhesive vinyl. That way they can just be stuck on and still be potentially visible at night.
Update 2: View attachment 84027
Excellent modification. I have been thinking about how to label these switches. Wow...those are above and beyond. Do you mind if we use these as a pattern? Thanks again.
Bronc-O
Phoenix
2021 Lincoln Aviator
If they are the same as Raptor, the aux portion lights up when in the on position.
Natai
Natai
Sean
Sacramento
Use as you like. I can send you the PSD file if it will help.
DUSTYcazOREGON
Craig
PrincipalD
Ryan
Sioux City, IA
Expedition, Bronco
This could be a nice little side business once finalized. Say you print this as a sheet (not sure how that really works on your end) and I would buy them - use the ones I needed. I want a well put together look, easy $20 out of my pocket.
Panzer948
Charlotte, NC
1981 CJ5, 2015 BMW M4, 2019 Jeep G.C. Trailhawk
I agree, I would buy the whole sheet as well and use what I want. I think the key will be to find good quality vinyl or paper that sticks on one side, which it sounds like you are doing with the glow in the dark idea (which is great BTW). Keep us posted!
JesseS
Jesse
Northern California
Jayco AY26, Honda F6B, CR-V
My wife does crafting so she can make any labels I need, she did it for all of the stuff I added to the Motor Home.
Rubisquatch
Pittsburgh, PA
2021 Bronco Wildrak
This is great, nice job.
I suspect there will be a whole bunch of aftermarket options, including buttons to replace these that light up and customizable.
Lowcountry Bronco
William
South Carolina Lowcountry
Squatch button makes your Bronco disappear ...
Ford Bronco Custom Aux Switch Labels / Stickers for 2021 Bronco 1612123214487
JesseS
Jesse
Northern California
:LOL:
Yeah, actually back lit would require a modification to the aux switch itself. That's why I'm planning to try this on printable glow-in-the-dark adhesive vinyl. Should be able to provide some illumination without having to mod the switch. Of course, if someone want to mod the switch, these could still be used easily.
Yes and no. I've got a Cricut that cuts vinyl, and I'll probably use it to cut these out cleanly after they're printed. But those cutters have a hard time with detail this fine, so it won't really work for cutting out individual letters. So I'm going to print the black over the glow so it shines through, then cut each label out as a single piece.
Of course, if the Bronco switches end up being a little different from the Gen2 Raptor, I'll have to make some adjustments first.
HAHA! My spouse also has a Cricuit and does the labels for all of her canning, and cards as well as things added to the M/H.
Norm A.
Norman
You can't beat Sasquatch flipping the bird 😜
