Looking great!!
I noticed that too. Thinking I might just put them in front of the switch. Just inside the inset area.
I love the idea of the stickers. Seeing the switch picture today, it looks like the application might be to cover the Aux X portion. The paddle might have a texture.
Excellent modification. I have been thinking about how to label these switches. Wow...those are above and beyond. Do you mind if we use these as a pattern? Thanks again.As seen in the Aux Switches and Accessory Rail thread, there's a lot of discussion about the aux switches. I came across a file someone created to make labels for the Gen2 Raptor switches and got to thinking about something similar for the Bronco. There are plenty of different labels out there you can by for upfitter switches, but I was thinking more of a Bronco style.
I've put together a few so far. Probably not the easiest to read, but it has the Bronco feel to it.
I'm also sticking with black and white, because my current plan is to print these on to glow-in-the-dark adhesive vinyl. That way they can just be stuck on and still be potentially visible at night.
Update 2: View attachment 84027
If they are the same as Raptor, the aux portion lights up when in the on position.
Use as you like. I can send you the PSD file if it will help.Excellent modification. I have been thinking about how to label these switches. Wow...those are above and beyond. Do you mind if we use these as a pattern? Thanks again.
I send you a message. ThanksUse as you like. I can send you the PSD file if it will help.
This could be a nice little side business once finalized. Say you print this as a sheet (not sure how that really works on your end) and I would buy them - use the ones I needed. I want a well put together look, easy $20 out of my pocket.As seen in the Aux Switches and Accessory Rail thread, there's a lot of discussion about the aux switches. I came across a file someone created to make labels for the Gen2 Raptor switches and got to thinking about something similar for the Bronco. There are plenty of different labels out there you can by for upfitter switches, but I was thinking more of a Bronco style.
I agree, I would buy the whole sheet as well and use what I want. I think the key will be to find good quality vinyl or paper that sticks on one side, which it sounds like you are doing with the glow in the dark idea (which is great BTW). Keep us posted!This could be a nice little side business once finalized. Say you print this as a sheet (not sure how that really works on your end) and I would buy them - use the ones I needed. I want a well put together look, easy $20 out of my pocket.
HAHA! My spouse also has a Cricuit and does the labels for all of her canning, and cards as well as things added to the M/H.
Yeah, actually back lit would require a modification to the aux switch itself. That's why I'm planning to try this on printable glow-in-the-dark adhesive vinyl. Should be able to provide some illumination without having to mod the switch. Of course, if someone want to mod the switch, these could still be used easily.
Yes and no. I've got a Cricut that cuts vinyl, and I'll probably use it to cut these out cleanly after they're printed. But those cutters have a hard time with detail this fine, so it won't really work for cutting out individual letters. So I'm going to print the black over the glow so it shines through, then cut each label out as a single piece.
Of course, if the Bronco switches end up being a little different from the Gen2 Raptor, I'll have to make some adjustments first.
I want the sound of the horn of the Mammoth Car from Speed RacerI'm going to believe that the Squatch button triggers either a train horn or a reggaeton horn.
You can't beat Sasquatch flipping the birdAs seen in the Aux Switches and Accessory Rail thread, there's a lot of discussion about the aux switches. I came across a file someone created to make labels for the Gen2 Raptor switches and got to thinking about something similar for the Bronco. There are plenty of different labels out there you can by for upfitter switches, but I was thinking more of a Bronco style.
Nah, just makes pictures taken of your ride blurry.Squatch button makes your Bronco disappear ...
