Could this be modified to be a hard top lift?
Shacky4
Sault Sainte Marie, Michigan
Big Bend Bronco
Looking at hard top lifts. I prefer a free standing lift to pulleys and straps. They are quite pricey. I'm wondering if you could take an engine hoist like this and modify it. Anyone done it or have some thoughts? These are from Harbor Freight and under $300.
Ford Bronco Could this be modified to be a hard top lift? 1645997776368
GoldenKnight
IL
Malibu
Haven't used one personally, but I'd be surprised if it goes high enough to reach a roof
ā€˜21OBX
90Bronco19
2022 bronco outer banks
I wouldnā€™t believe it would go high enough. Heck a low budget solution would be a come along pulley and some straps.
BroncoAZ
Mitch
2021 2 Door Badlands manual, 2021 Tacoma TRD OR
The max height of that wonā€™t be that much more than the height of the top, the straps will be very tight out to the sides. I donā€™t think it would be a good solution.
swami37
Fort Lauderdale Florida
1950 Ford F-1 and 2020 F150 FX4
Never lift high enough.without major modifications
Lifeliberty
MoonbeamšŸ‘€
Columbus, OH
If you're going to muscle around an engine lift, you could just take the top off yourself.
It can go high enough if you extend the arm out, but you'd be pumping forever. You'd look like popeye, so i guess it does have its benefits...
Definitely more trouble than it's worth
Lifeliberty
MoonbeamšŸ‘€
Columbus, OH
A guy modified a dry wall hoist. This looks like it may be better suited.
That'd leave indentations in your soundproofing in the top. Depends on what you can live with
I need to see the top in person, but I'll probably do what i did last time and suspend it from ceiling with chains to wood boards underneath.
I like wood boards because then there's is no flex as you do with just straps. The more you can make it so it's as if it is sitting on the ground(or still on bronco) the better
Then i just park in garage with my hood under the top
A lot will depend on your space and abilities.
But if you cant reinvent the wheel, and i don't think you should, just get the harkin and call it a day
Kennys2g
Kent
Central Bucks Co. PA
ā€˜12 JK
Iā€™ve used the Harkin for my JK roof and it worked great.
Itā€™s still hanging in my garage waiting for my EG Basesquatch.
Shacky4
Shacky4
Big Bend Bronco
As I mentioned in my first post, the ceiling hoist doesn't work for me and these lifters are so darn expensive that I was trying to figure our a way to modify something less expensive. I'll probably end up biting the bullet and going with this. View attachment 276988 View attachment 276988
Lifeliberty
MoonbeamšŸ‘€
Columbus, OH
Slow down there. You said you have a preference, not that you couldnt do it...
If you can't do it then you're going to need some space. At least the new top isn't one piece anymore so that will help. You might get some saw horses to set it on. This is out of my territory of experience. Good luck!
What are you working with?
Flourman
Centennial, CO
2022 F350 Tremor, 2019 Beta 300RR
I really think the $30 kayak hoists will work for a hoist.
