Console Insert
2024 Ford Bronco
I ordered a console insert for my 2024 Outer Banks. Fits perfectly and makes much better use of the console storage area. As an added bonus I now have a hidden compartment in the console base.
Ford Bronco Console Insert 1000018299
Ford Bronco Console Insert 1000018300
dejones64
Dan
MN
Bronco 2-dr Black Diamond
I have this also, I do like it, but, a pain to get to the 12v charger port. I use it for a fridge or solar battery unit. The top tray needs to be removed in order to use it.
Ggerobb
Gordon
Bennett, co
94 jeep grand cherokee laredo, 2022 bronco BD
I have this insert as well. I found it to be a pain. It needs a better grip point in the middle for removal. It's slipped many times on me. Especially when it has coins and such. I glued a binder clip in the middle to help in removal and it works better now.
JackM
Lockport NY
Bronco and F150
I ordered a 3' 12v extension which I can leave plugged in and that way you dont have to keep accessing the console storage. I use mine for a radar detector. The extension also has a cover attached that you can cap it with when not using.
dejones64
Dan
MN
You can insert the top tray when it's plugged into the port?
helifino16
Ron
Mount Sinai, NY (Long Island)
I found that this tray requires 2 hands to remove and replace comfortably. I saw a suggestion to drill 2 holes and put a piece of Paracord as a grab handle. I have found that a 3 point pickup would have been better. Not sure if I'll get a new one since I'm not in and out of here that much.
I believe that they also had a 2 part tray (one on top of the other) that you could get also. Anything is better that the tiny tray provided or just having a huge console to lose that chap stick in there.
Bright Red Bronco
2024 Ford Bronco
I haven't had the need yet to remove the tray but this is great feedback. I may give the para cord idea a try. :thumbsup:
broadicustomworks
Hanging Rock, North Carolina
I have the 2-part one (Wife got it on Amazon, I am sure). It is a really big useful upgrade for little cost.
Not perfect by any means, but far better than the single tray or none at all.
Robs
Rob
New hampshire
2023 Black Diamond
i have one like that. It constantly falls into the console and spills all its contents. I eventually added some Velcro to keep it in place and that has helped.
Bright Red Bronco
2024 Ford Bronco
Mine has been very stable in there and seems to fit perfectly. :cool:
