Confirming base plastic bumper has fog light harness preinstalled?
cyoungk
C
CA
Bronco Big Bend
Sorry if this has been covered... but I'm planning on adding fog lights and switching the headlamp switch to include fog light switch (anyone have exact part number?). I'm sure others have already done this, but I've been reading some mixed comments on whether all models come with fog light harness behind the bumper?
Much appreciate any help!
Fat dog
Austin
1986 Mustang GT
I assume you are adding the modular bumper. Add the switches as well. Every bronco should be ordered with the switch bank
bishop0577
Robb
Corvallis, OR.
2021 Bronco 4 door base/sqatch
I have a 2021 Base 4 door Sasquatch and mine did not come with any harness or wiring for fog lights. No big deal though. Pick your lights, cut your holes in the bumper (the piece that you will cut into actually pops off the bumper) and wire them up. I do have the aux switches though. Made wiring it up a lot easier.
tilebroncodude
Derrick
Philly burbs, Pa
24 Big bend 7M, 21 f150 lariat
I'm curious to if this has been done. I am wanting to do the same thing
Fly by Nite
Walt
Pa
My '23 BaseSquatch with mod bumper doesn't have the fog harness in the bumper.
I've read you can tap into the wiring harness plug that ends in the drivers side wheelwell. That's where the bumper harness would plug into. You can then add the headlight w/fog switch to control them.
More info in this thread, and watch the vid in post #219
https://www.bronco6g.com/forum/thre...-factory-connector.40448/page-15#post-1863054
