SVTLightning
Christian
Canada
Titan
-29 here a couple days ago, no real issues. Steering gets stiff and my feet get cold thanks to Fords worthless, horrible, pathetic, embarrassingly underpowered floor heater but I survived.
Lucy the Bronco on IG is based in Fairbanks and was in the -40s 🥶
My feet cook in mine at -35°C lol.
Belle
Lori
South Dakota
‘85 FXSB, ‘01 XL1200, 2022 Black Diamond Sasquatch
Yesterday morning’s commute.
Ford Bronco Coldest Temperature Driven in Your Bronco? 25BC1188-CBF7-4C54-962B-184DAAE46471
HoosierDaddy
__ Eric
I seem to have much better results when I turn off the fresh air button ... repeatedly🤬 ... probably the single most irritating thing about the new Bronco is that button self resetting every 5 minutes.
I've considered looking into the damper actuator, having it close and then pulling the plug on the actuator.
It seems like when it is pulling in fresh air, the entire center console is freezing cold.
John Auer
Captree Island, NY
Lincoln Nautilus, Ford Expedition
Name a Country in the world that doesn't use Standard socket ratchets (1/4", 3/8", 1/2")? Sigh......
Isn’t it kinda crazy that we need two sets of tools? I bet the tool manufacturers love it. Merry Christmas 🎄!
danofcrowhill
dan
Red Lodge, MT
F250
I went to get into my 2 Door today, and both the driver and passenger windows are froze/stuck shut. 0 degrees outside.
I keep my windows cracked about 1/8" in this weather (-20 here in southern Montana). Just enough that they don't have to move when you open the door.
John Auer
Captree Island, NY
The vast majority of science uses "non SI units acceptable for use with SI", because actual metric units are simply poorly sized for most scientific measurements.
Astronomy uses light years, solar mass units, and AU, instead of meters and kilograms.
Particle physics uses electron-volts, and atomic mass units, not Jules and kilograms.
And of course we use Kelvin not Celsius, but at least those are the same scale.
Vacuum science uses Torr, not Pascals.
E&M is the major exception that actually uses metric units, but that's because the science of E&M came into existence after the metric system.
But my degree is in materials physics.
I’m an accounting major, we use dollars and cents 🤣. Merry Christmas 🎄
lewishamilton
Canada
17 VW Golf R
US folks you are gonna be fine.
Central Canada here. I have driven in -40C/-40F. Everyday in winter is around -20C/-4F to -30C/-22F.
Remote start 10 mins helps a lot.
Soundgarden
The Dude
Northern Canada
Bronco Badlands-Suburban 2500
So,
With the Arctic Blast moving through the country and impacting millions of people.
I would like to know who has driven the Bronco in super Cold Temps.
I left work yesterday and it was -1°
The doors were a little sticky but window operation was good -- how it lowers and raises with door.
I'm in Central PA.
So, how did your Bronco handle the cold?
I work in Northern Quebec and last year we hit -40 in Matagami, good thing we have block heaters
Ford Bronco Coldest Temperature Driven in Your Bronco? 43BD68E2-A3DF-4799-B9C1-802DE5D08614
joeb
Pennsylvania
FJ Cruiser
Yeah, I figured we would be good down to -20 or so. But, wanted to know what others have experienced.
Thank you
Macjr
Martin
Northern NY
Toyota Tacoma TRD Offroad, 2020 Volvo xc40 RDesign
I’ve had my soft top and have had zero issues with the cold, I did however just get the DirtyDog4x4 bronco headliner and it made a MASSIVE difference in quieting down the cabin and retaining heat, absolutely love this add on.
JC2DR
Joseph
Maine
Bronco Base 2dr 2.3 7speed
I was in the cold, wind and snow of Ohio. -1° 22’ Base 2.3 manual handled like a champ!
Ford Bronco Coldest Temperature Driven in Your Bronco? 111F5DC9-7DC7-4E5D-94FA-ED5890FB6777
Ford Bronco Coldest Temperature Driven in Your Bronco? 62C561D3-4C55-4730-9760-9F72A1848EDC
Ford Bronco Coldest Temperature Driven in Your Bronco? FE62E4D9-D0F2-4D19-96D1-B03D23474935
Ford Bronco Coldest Temperature Driven in Your Bronco? AA54A0E0-44DB-4A9F-8876-D363FAA0C31D
