Dwillisbronco
Missouri
Outerbanks 2.3
Was out the past 2 mornings with -28F wind chills. I was very impressed with the soft top. The cabin heats up very fast, as the heated leather seats.
I found if I turn off the auto for air/heat and change settings for both floor and cabin, I set the fan speed to 4 and temp to 68 was very comfortable.
I also used the Slippery GOAT mode for the ice/snow packed roads and it had no issues taking off on a steep incline. No tire spinning!!
joeb
Joe
Pennsylvania
FJ Cruiser
I went to get into my 2 Door today, and both the driver and passenger windows are froze/stuck shut. 0 degrees outside.
I will admit I remote started it for 10 minutes. Not sure if that helped with the doors ( set on Hi Temp at fan speed 3 )
rtazz17
Rob
Connecticut
2022 Ford bronco big bend
I have found all the complaints about the soft top being cold and buying insulation to be false. 4 degrees here with 20 mph winds on top of it. Very warm inside vehicle.
Cable Guy
Kurt
Audi RS7
Only had it two weeks but so far -13F maybe -35-40F with wind. Temp inside was fine. Even with the soft top
72F262
Doug
Charlotte
18 GT350, 72 Mach 1, 22 Bronco 2 Door
We were in Denver when the blast came through. Had been skiing at Keystone the days before. Drove across CO & KS to get back to KC on Thursday. Leaving Denver it was -19F. Winds were CRAZY cold, -40 to -50 wind chill. Finally warmed up to 0 in the afternoon. Stopped in Hayes, KS for lunch and the gusts were brutal. Bronco did great. I know some have complained about the floor heating. Mine works great. I have a 2 door and my daughter in the back was a little cold with the cold wind blowing in via the windows. You can't really blame Ford for basically driving 75 in a wind tunnel sideways.
I can report, 85mph with strong 20-30mph wind going out, no storm, I was getting 15mpg. Slowing down to 75 during the storm on the way back, I was able to get 22mpg. Wind was always at our side both directions so no help there. The 2.3 does get thirsty at 85.
Gassyjack
United States
-17F with close to -50F windchill. Had the bronco plugged in outside and had no problem keeping the interior warm. I had added a sunscreen and put a heavy blanket between it and the soft top for wind noise. The added insulation sure didn’t hurt.
The rest of the vehicle was a little stiff getting going.
JerryC
Memphis
2022 Bronco
1 degree F. Here in the Memphis TN area.
RagnarKon
Bryan
New England
Ford Bronco, Escape, Focus
You're in the USA and you use Celsius?! What the F...ahreneheit!
Coldest I've been is is probably -10 C. The soft top holds in the heat really well - Pretty pleased by that!
Hah, yes... and my wife hates it.
I studied electrical engineering in university, and for my senior capstone project I assisted a bunch of graduate students as we develop battery-powered weather stations that could survive in frigid cold temperatures. All of the weather stations are programmed in Celsius, and it eventually it became more natural for me to use Celsius in my daily life too. It's not super easy to convert between the two in your head, so I've memorized a handful of conversions (ie. -30°C = -22°F, 22°C = 72°F, 38°C = 100°F, etc.) and for the in-between temps I just guess.
It still drives my wife insane because anytime she picks up my phone or goes in my Bronco everything is set to Celsius.
I guess the strange part is I still use miles per hour rather than kilometers per hour (the weather stations were programmed in knots). Luckily for me the United Kingdom also uses MPH and Celsius in their cars, so I usually just set my electronics to "UK units" and that gets me what I need.
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
Ford Bronco Coldest Temperature Driven in Your Bronco? 1671900390826
Don‘t tell @Tricky Dick - He’ll get jealous but pretend he doesn’t want this.
Shazamalingo
West
2022 OBX SAS
Lol. I've used both systems for decades (all science is in metric) in the US. Can't wait until the US rips the bandaid off and goes metric. Sigh....
DogHauler
Chuck
New England
2022 Badlands Sasquatch 4dr 2023 Black Diamond 2dr
Should be fine to at least -30F, most OEMs validate down to temperatures lower than that.
BigBendBW
Columbus, Ohio
Bronco Base Sasquatch
So,
With the Arctic Blast moving through the country and impacting millions of people.
I would like to know who has driven the Bronco in super Cold Temps.
I left work yesterday and it was -1°
The doors were a little sticky but window operation was good -- how it lowers and raises with door.
I'm in Central PA.
So, how did your Bronco handle the cold?
-4 and was a champ, super high winds too
Highmtnbronco
Arctic blast brought temperatures around -16 below zero Fahrenheit in my area. I was driving around and everything functioned properly, just a little squeaky and rattling until things warmed up.
Ford Bronco Coldest Temperature Driven in Your Bronco? 1C8C539D-D500-40E4-9BB7-4235A242560B
Ford Bronco Coldest Temperature Driven in Your Bronco? 0A631CCC-4211-453A-BFE4-C7801D4B0470
