Clutch Replacements?
skap407
Orlando Florida
Bronco Sport
I have a 22 Big Bend Manual with a lift on 35's for background. I was driving home today and saw an older F-350 dually on the side of the road axel deep in sand ( i live in a more rural area of FL.) It looked almost as if he was trying to make his own trail and got stuck so I pulled over to see if I could help. I find out he was ran off the road and he crashed into a chainlink fence and was wedged against a electric pole. I was able to get him out luckily but completely burnt my clutch up I am assuming because now I have barely enough meat left to shift and it grab the gear. Does anyone know of aftermarket clutches yet or the pricing of OEM clutches? I have not been able to find any and If I am going to have to replace it anyways I figured might as well explore my options. It sucks because I was trying to do the right thing by helping but it looks like I just put myself in a bind.
Nateandapril
Nate
Bronco Badlands non Sas Area 51
Ouch, man that sucks.
skap407
skap407
Orlando Florida
Bronco Sport
It is what it is Im glad I was able to help the guy cause he was in a bad spot and the Bronco is a freaking tank. I wish it wouldnt have ate my whole clutch but you live and learn
TX-Hans
You might reach out to 4wheelparts.com They apparently have some special factory relationship with Ford on the Broncos. It's a bit of a long shot but perhaps they might know the answer or at least might be able to find out from Ford.
Tricky Dick
Dick
PNW
www.TD-Distributing.com
I think the Broncbuster guy has done clutch testing and was working on a HD aftermarket one. You could look into that.
wetdog
Bruno
pacific coast
2019 jl
No good deed goes unpunished, I would have done the same thing.
As far as I know ford might be the only option ,check with dealer Monday am and good luck to ya.
P.s. what part of fl?
HoosierDaddy
__ Eric
NW. Indiana
I have a feeling the clutches in these things are very fragile.
They burnt the Off-rodeo Broncos up in short order.
The claim was too many people not knowing how to drive them properly.
I'm not buying that excuse due to this story and my own gut feeling on the clutch in my Base.
Curious, did you use low transfer or at least the "crawler" gear while doing this?
I noticed the 35's make the 4.46's feel a bit too tall, which would force you to slip the clutch too much.
Bronccoli
Noah
Mitsubishi Outlander
Have you looked into bleeding the clutch? I find it pretty hard to believe you burnt a brand new 2022 clutch in once instance. Did it smell like burning clutch when you were pulling it out? Hoping you get some good karma from pulling the 350 out
skap407
skap407
Orlando Florida
Bronco Sport
This is a good idea they actually did my lift
skap407
skap407
Orlando Florida
Bronco Sport
I might look into this. The pedal is very tough to push in now and it feels like its barely grabbing the gear thats the only reason I was thinking clutch.
skap407
skap407
Orlando Florida
Bronco Sport
So I will vouch a little for the clutch I have done some wheeling and I've been a huge fan of it. But I think after today I might agree it almost in a sense feels a little too soft for how much torque there is. And im not new to manual either so I know it wasnt from prior use it was exclusively from this time. I did make a mistake and I had it in 4H and thats when it happened but I switched to 4L and crawler and he came right out but the damage was done. Sorry for long response lol
skap407
skap407
Orlando Florida
Bronco Sport
Yea I work at a ford store so I am hoping it wont be too much damage. It did feel good to finally help somebody out . This was very close to Groveland coming from Astatula
mike8675309
Minnesota
If you burned up the clutch, you did something wrong. If you were doing everything right, and not abusing the clutch (flywheel and/or pressure plate will be completely burned up if you were abusing it) then it would be a warranty. Otherwise, it would be your dime, possibly insurance would cover it?
It is perfectly reasonable to believe a clutch disk could be bad. Or there could be a dimensional issue in the pressure plate of the flywheel causing clamping force to be too low. But generally, the last two would be noticed in daily driving, particularly if accelerating up an entrance ramp or trying to pass someone.
skap407
skap407
Orlando Florida
Bronco Sport
Actually pretty impressive that you tugged that f350 with a 4cyl. Sorry about your clutch.
Yea I was so impressed because I thought forsure with how stuck he was that I wasnt going to do anything but I at least wanted to try and if not then post on FL SOS page to get help.
