Clutch creaking
Gil Carolina
Gil Carolina
Gil
Charlotte
I’m on my second clutch. First was replaced. Drives fine just creaks. I’m scheduled to have it replaced again.
Francisco A
2022 Bronco Big Bend MT
Hi there! I can assist with your clutch creak concern. Could you send over a DM with your VIN and Ford dealer info?
Hello. I just provided the info. Let me know if you need anything else.
Thank you very much for the help.
Francisco A
For those having this issue, do you know if yours was a delayed vehicle (dirt or ice mountain)?
The Bronco has a hydraulic clutch.
That limits possible creaking noises to:
  • Pedal pivot point
  • slave cylinder
  • pilot bearing
  • pressure plate fingers
Corrosion on the pressure plate assembly could result in creaking noises and would be indicative of a vehicle left in the elements for a long period of time without driving. This would be the first thing I would look at.
Corrosion on the slave cylinder could cause it to make a noise when it is actuated and would be the second thing I would look at.
3rd I would look at the pilot bearing, only if the noise was constant. Noise only when applying force to the clutch pedal, or releasing force from the clutch pedal will be one of the other things.
Thank you for your feedback. Mine was built in June/July and delivered in early September.
libtech
Libo
Subaru WRX
Woh, I was on ice mountain and recently noticed a rattling feeling and rhythm creaking noise started around 1000 miles ONLY when stepping on the clutch pedal (“disengaging the drivetrain from engine”) . Slowly getting worse but not clear slippage. Noticing mostly 1st / 2nd / 3rd.
Haven’t even really off-Roaded (light trails) and I treat it gentler than my wrx which is on its original clutch at 80K miles. Have a dealer appt coming but a little surprised with potential problems with such a new vehicle (even if Ford’s reputation for reliability is near bottom these days…)
  • Pedal pivot point
  • slave cylinder
  • pilot bearing
DesertMike680
Las Vegas
  • Pedal pivot point
  • slave cylinder
  • pilot bearing
Mine was on dirt mountain for probably 3 months during the summer. Clutch pedal started to squeak at about 8k miles.
mike8675309
Minnesota
Is the squeak on the inside pivot or coming from the outside under the vehicle? In theory, all of those joints could be lubricated. The throwout bearing or pressure plate fingers should clear up squeaking by themselves over time.
DesertMike680
Las Vegas
This is coming from inside the cabin. So much so that I can feel it squeaking through my foot, which leads me to believe that a joint needs to be lubricated in or around the pedal.
mike8675309
Minnesota
Since it is still under warranty, I would have the dealer deal with it if you can. that way if it is a dry bushing or bearing that should have been replaced, it will get replaced.
jsoa
Jose
Delaware
2024 Bronco 4dr
having the same issue, took it to dealer today, they didn't do anything, instead im scheduled to drop it off in a few weeks so they can investigate for a few days, and they are getting me a rental in the mean time.
will update when I know more
Imaginary Friend
Southern MN
A passel of Fords and a Jeep JL Rubi
Hopefully the manual Broncos aren't afflicted with the broken weld/pedal assembly issues that plague the S550 Mustangs. In those, a creak in the passenger compartment when engaging the clutch pedal means a cracked weld that is about to fail....
DesertMike680
Las Vegas
Funny enough - my Bronco has been at Ford for a week and a half. Getting the clutch pedal assembly and master cylinder replaced. Thankfully all covered under the warranty.
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Hi Jose! I can look into your Bronco's concern on my end. To get started, could you please send a private message over with the name/location of your local Ford dealer and your Bronco's VIN?
Tylander
Tyler
Everglades
I am having the same issue. Creaks coming out of first and second. Started at about 600 miles, currently at 688. Better make an appt with my Ford dealer.
jsoa
Jose
Delaware
2024 Bronco 4dr
FWIW, I swapped the clutch spring with the steeda one and I have not heard anymore creaking. Not saying it was spring specifically, but perhaps due to the new spring being softer, its less stress on components around it. Hope this helps.
jsoa
Jose
Delaware
2024 Bronco 4dr
So after a week or so the creaking returned, odd, perhaps I was not hearing it initially, but upon further looking I may have found the source of the creaking. Here is what the back of the pedal looks like. shitty welding?
Ford Bronco Clutch creaking PXL_20250521_003909691
No idea how to fix this
