Cleaning help! Can't remove marks off plastic fender flares
Aidan
GA
2018 Ford Expedition, 2016 Ford Fiesta ST
Just wondering if anyone else is having this issue or not. I have the plastic fender flares with the sasquatch package so I expected mud and rocks to sling up but i can't seem to get them cleaned. I haven't taken it "off-roading" really. All the mud I've picked up from my short dirt driveway and anything on the highway. Washed it first with a soft wash mitt, soap and water and it dried like the photos. I tried a harder sponge and scrubbed it pretty hard and today I took it to a car wash and used the pressure washer and still no change. The dark spot on the fender is just a wet spot I tried to clean with my thumb. It dried like everything else. Thanks in advance.
Try getting a plastic safe all purpose cleaner. Gtechniq W5 is pretty intense and cleans very well. Spray it on the fender and take a stiff bristle brush and give it a good scrubby scrub. If it doesn't come all the way out, just repeat a couple of times, working in small sections. Wash, rinse and dry.
For longer protection, try applying Gtechniq C4 Trim Restorer, great product, rejuvenates plastics, darkens finish, provides a level of protection and water repellency. Some suggested Trim Solution. That is also a good product, very messy though. Have to be more diligent in it's application. It uses suspended charcoal powder that soaks in to the plastic pores to bring it back to life. However I would recommend trying to remove the stains first. Trim Solution is a dressing, it doesn't remove stains.
GoTigersGoBronco
Zachary
Memphis
Toyota 4Runner
I’ve used a melamine foam block (magic eraser) for some things like this on black plastic.
JBTHERAT
Jon
Houston
‘24 Highlander, ‘15 Taurus, ‘18 Edge
I was able to remove my stains with Folex (carpet spot remover). It worked extremely well. Sprayed on agitated it with a toothbrush, let it set for maybe a minute and rinsed off. When dry, ceramic coated them with Adams Graphene. I’m completely satisfied with the results.
Ford Bronco Cleaning help! Can't remove marks off plastic fender flares 343FA3B1-B9F2-4F5F-9467-C29B5BB51E42
JBTHERAT
Jon
Houston
Also, Spray and Wash (laundry) worked as well.
helifino16
Ron
Mount Sinai, NY (Long Island)
Someone said to try Scrubbing Bubbles.
Jewelsland
Julie
Salt lake City
Had the same problem. A small scrub brush and dawn dishsoap did the best cleaning job, but it still looked stained and sun bleached. After cleaning it, I put on the chemical guys VRP as recommended in other comments and that did the trick. It looks beautiful, new and nice and shiny black!
Wilbur's son
Hesston, KS
2001 Ranger 4x4
That is what I use. I picked up some manure slop from a cattle trailer. That spray was on both flares and rock rails. Scrubbing Bubbles cleaned it right off.
Bschurr
NY
Sardine
2022 Elantra N - 6 speed & 2023 Badlands
i heard you can get that stain out with Tide bleach and a steel sponge.
Not sure if this was a joke but do not do this.
