Chock Recommendations
seuslee
Jesse
Louisville
2024 Ford Bronco Black Diamond Sasquatch Edition Cactus Grey
I use Haul Master rubber wheel chock with eyebolt with a 3 foot chain from Home Depot and 2x Everbily 5/16 in. X 3-1/4 in. Zinc spring link.
Ford Bronco Chock Recommendations IMG_5414
Inakomislu
Inakomislu
usa
bmw
I picked up a pair of rubber wheel chocks a few months ago and they've done the job well on my gravel driveway. They’re solid enough to hold my Bronco in place, even on a slight incline. I like that they don’t slide around and don’t damage the ground. Definitely better than the plastic ones I used before.
CalvinT
Calvin
Phoenix, AZ
I like that you can't forget your chock if you forget to remove it and just drive off.
orion
Jeremy
17' F-250, 17' Explorer
Also, with an MT if you leave it in gear and don't engage the e-brake the clutch can slip on steep inclines thereby allowing creep. With an AT the park pawl will lock the flywheel.
It's not the clutch that slips, it's the lack of engine compression that allows it to roll. The engine is turning over...
Apollo
F350
With your steep driveway the biggest danger you have is parking on ice and snow. Chock or not you could find your bronco at the bottom of your hill. Over the years I have made this mistake more than once.
I use firewood. Probably not the safest thing
CalvinT
Calvin
Phoenix, AZ
That's why you should always leave a manual in the lowest gear when parking if pointing downhill or reverse if pointing uphill. If you really want to get carried away, put in in 4L every time you park. :ROFLMAO: :angel:
orion
Jeremy
My driveway is not steep. 4Lo will not help this and it will still roll, 4.7 gearing too.
My driveway...
Ford Bronco Chock Recommendations IMG_20220105_171602_648
Beachin 74
Delaware
